KW COILOVER LOWERING KITS. B7 , B8 , C6
Please read the "RS246 Group Buy Policy" in this forum before use.
Trups
Trader (Expired)
Re: KW COILOVER LOWERING KITS. B7 , B8 , C6
Post by Trups » Sun Apr 21, 2013 11:11 am
grizz wrote:Once 5 are required I'll need every one to call us a place a deposit .
Once all have done this I'll place the order .
When they are ready to be shipped from KW I'll require full payment .
So how many confirmed so far then?
Can we get a list so we know?
Trups
grizz
Post by grizz » Sun Apr 21, 2013 12:13 pm
If interested please add your name -
Unit 20
0151 3366888
Trups
Trader (Expired)
Post by Trups » Sun Apr 21, 2013 12:53 pm
grizz wrote:If interested please add your name -
Trups - C6 RS6
Post by MikeFish » Sun Apr 21, 2013 8:30 pm
Trups - C6 RS6
MikeFish - B7 RS4 Saloon
otterolly
Post by otterolly » Sat Apr 27, 2013 3:04 pm
interested - B7 RS4 Avant
Post by MikeFish » Sun Apr 28, 2013 8:53 pm
Just 2 more needed then? Anymore takers?
I'll post a thread about this in the B7 RS4 section as I bet there are loads who only browse specific forums.
Nickyboy
Post by Nickyboy » Sun Apr 28, 2013 9:16 pm
Any chance of getting anything on a B8 S5 3.0T?
Also, if so what's the difference between these and springs? I'm about to order 25mm H&R springs but could be tempted on this depending on what the difference is.
2011: 2.0T FL Octavia VRS
2010: 1.8T Octavia VRS
Gavla
Post by Gavla » Sun Apr 28, 2013 10:35 pm
Gavla - B7 RS4 Saloon
RS4 (B7) Saloon Phantom Black, Black Optics, Tech Pack, KW Lowering Spring Kit, Stern Adjustable Arms, MRC Stage 2, Stage 1 Manifold, CAF, LOBA Stage 1 Clutch,
447ps/490nm (MRC), Scorpion Exhaust Non-Res Black Tips, Pre-cats gutted, Shadow Black Chrome Alloys, Viper Alarm, LED Interior lights, Tints
grizz
Post by grizz » Mon Apr 29, 2013 6:29 am
Nickyboy wrote:Any chance of getting anything on a B8 S5 3.0T?
I'll find out today .
grizz
Unit 20
0151 3366888
Post by MikeFish » Mon Apr 29, 2013 6:47 am
This kit has adjustable ride height whereas springs normally are fixed height.
Nickyboy
Post by Nickyboy » Mon Apr 29, 2013 7:23 am
Cheers for that. Next questions, once you have found the height you like why would you ever need to adjust them? Also, how easy is it to adjust them?
Thanks in avance.
Trups
Trader (Expired)
Post by Trups » Mon Apr 29, 2013 7:36 am
Trups - C6 RS6 Avant
otterolly - B7 RS4 Avant
Post by MikeFish » Mon Apr 29, 2013 8:35 am
Nickyboy, this is what Grizz said about adjusting after they've been fitted:
grizz wrote:Once fitted it ok to adjust , takes a bit of time on the rear but not too bad .
Yes it keeps the drc .
That was in reference to the B7, I don't know if this would be the same for the B8.
I might want to adjust if the original setting was too low and I am scraping a lot or rubbing on the tyre, or if the original height wasn't low enough and I find that ground clearance is still fine.
You might buy new tyres that are a little wider or squarer and find they rub so might need a little lift. I guess it depends on how low you want it. I want it quite low so might need fine tuning to get it exactly right. If you are riding higher then once you set it you probably won't need to touch it again.
Nickyboy
Post by Nickyboy » Mon Apr 29, 2013 8:55 am
MikeFish wrote:Nickyboy, this is what Grizz said about adjusting after they've been fitted:
:thumbs:
shinz
Post by shinz » Tue Apr 30, 2013 12:49 pm
Hi Grizz,
I would like to join the group buy, if you can supply me a set to Australia.
I have sent you an email, if you could respond when you get a chance.
I think I also need a new left rear DRC shock for the B7 RS4, if you can supply me this also?
Thanks,
Greg
Return to “Group Buys”
