Door Handle Problems
Re: Door Handle Problems
The door trim comes off really easily.
Once you have found the little hole under the window switch it isShoppinit wrote:The door trim comes off really easily.
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Have same problem with drivers door,but at present can't get door to open at all...will try again this weekend,can't take door trim off to have a gander until i get door open....... WAFFY
RS 6 Avant,
Ebony black mettallic,03 plate,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
Good link, MAV. I'm gonna put it in the FAQ.mavada wrote:http://www.youtube.com/watch?v=wx-BfcuK8b4
Where do I know that car from? It it Eddie's?
If it's that easy to remove the door trim, then I'll have a crack at this shortly.
Not sure I'll know what I'm looking at once it's off though. Will probably check everything is done up properly and lube up any parts which are supposed to move.
*SOLD* - currently looking for a replacement
03 Missano Red Avant
Silver Leather, H&Rs, Dension iPod Connection kit
85k miles
85k miles
RustyBucket
- 2nd Gear
Slightly different but my passenger door lock is pretty much worn and keeps bouncing off the latch and needs replacing. Where did you get the lock done on yours Dave?Not had precisely your symptoms, but I have had to have a door lock replaced on both of mine - had one done last night! New lock is £123 and about an hour to fit. In both cases it was the internal latch mechanism that was basically worn out.
Door card does come off really easily. I couldn't see anything broken or loose in there. Squirted a bit more lube around the mechanism while I had access but this didn't seem to cure the problem.
Put up with it for a while but was becoming more of a constant problem rather than intermittent.
Got the Audi dealers to fit a new lock mechanism the other day and it has been fine since.
Part number on the invoice looks like A402 837 016 039058/Door Lock if this helps anybody else. Was the driver's side one.
85k miles
85k miles
How much did they charge you Chris?
I bet he's still sorechunky79 wrote:How much did they charge you Chris?
It's useful to know when the topic is bought up again. I would have said around 1 1/2 hours labour.
Haha - it was the usual level of charges you would expect from Audi.
£120.77 for the part and not sure about the labour part as I had a few other things done at the same time.
Guess it worked out to be around £150 for labour ish.
85k miles
85k miles
Should be an hour max to fit IIRC
Anyone got the part number for the plastic but that wears on the push rod?
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
Has beens:
Mines had new locks as well which sorts the prob
950 nm torque!
Ohh running bridgestones because they are the best
Users browsing this forum: philS2 and 1326 guests
