Has anyone 'upgraded' to the 2010+ RNSe?
PetrolDave
Re: Has anyone 'upgraded' to the 2010+ RNSe?
Post by PetrolDave » Sat Feb 23, 2013 11:33 am
MikeFish wrote:Thanks Dave, seen it now, but it just tells me what the volume is currently set at. I don't see any way of adjusting. If if turn the volume up to lets say max (30) then go come out of that menu, turn the volume down then go back in, it just shows me what the volume is currently set at.
What works for some people (but not all like I said earlier) is to set the volume you want, exit Engineering Mode then completely turn off the RNS-E (i.e. lock the car and wait a short while - as the RNS-E stays turned on until either you lock the car or 30 minutes after you turn off the ignition).
Then unlock the car and turn the RNS-E on, if it's worked then the startup volume will have changed - but as I said before, this doesn't work in every case and in 7+ years nobody I know has worked out why it does or doesn't work.
Post by MikeFish » Sat Feb 23, 2013 11:12 pm
Ok Dave, I didn't turn it off. I'll try it again.
Firestarter
Post by Firestarter » Fri Aug 02, 2013 10:59 am
Hi Guys
resurrecting this old thread. Can anyone confirm that the below RNS-E unit is what I need to upgrade the existing head unit? Also looking at this its got a matt grey screen bezel so looking like it will just be a straight swap and no messing about trying to get the bezel off??
http://www.ebay.co.uk/itm/Audi-A3-S3-RS ... 338428ce9f
Also I will want to swap out the CD changer for a MMI and again just checking if the below item is correct and also do I need any further parts to get this lot up and running?
http://www.ebay.co.uk/itm/171069625468
Thanks in advance guys :thumb:
Louie
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT :-)
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre :-)
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
Yanos
Post by Yanos » Fri Aug 02, 2013 4:30 pm
I'm considering doing this in the next few months, but I have to retro fit as I have a single din installed at present. I found this:
http://www.ebay.co.uk/itm/261125348116? ... 1438.l2649
Should be a straighter swap? Bit more expensive mind you.
RS4 B7 Misano Red Saloon / Black Optics / Revolution - Pipercross Carbon air intake / Carbon Clean / Black Rings / Lepsons Black Chrome Alloys
Firestarter
Post by Firestarter » Fri Aug 02, 2013 6:46 pm
Hey Yanos :bigwave:
yeah that's a nice unit but I want to try and get one (if possible) with a matt grey face. That will save the effort of changing the screen bezel and mean I can then stick the existing unit straight on eBay to recoup some of the outlay. Gonna search around and see what I can find other thing is I may also get a MFSW to control this unit but need to understand where the sport button is then operated from? :? :? :? :? :? :? :? :? :? :?
Oh where for art thou PetrolDave :bowdown: :bowdown: :bowdown:
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
PetrolDave
Post by PetrolDave » Fri Aug 02, 2013 6:51 pm
Firestarter wrote:I may also get a MFSW to control this unit but need to understand where the sport button is then operated from?
It's fitted on the dash beside the parking sensors etc buttons.
Firestarter wrote:Oh where for art thou PetrolDave :bowdown: :bowdown: :bowdown:
I've been sorting out some PC and printer problems so I couldn't get online much yesterday.
I've replied to your PM (don't buy the unit you sent me the link to, it's NOT a 2010+ unit).
Yanos
Post by Yanos » Fri Aug 02, 2013 7:52 pm
HIYA!
No worries dude I know what you mean. That guy on eBay seams to have all the stuff though so maybe drop him a message?
Firestarter
Post by Firestarter » Fri Aug 02, 2013 8:14 pm
Just pinged him....I wait with Gusto for his reply!
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
armyair
Post by armyair » Fri Aug 02, 2013 9:14 pm
Although I run an older C5 RS6 it had the RNS-E as standard.
Hence when I acquired it the DVD drive was trashed.
I've recently had the 2010 RNS-E from an A3 fitted with LCD etc alongside OEM Bluetooth and AMI.
A really knowledgeable retro fitter from Manchester sourced and carried out the fit for me and had stacks of goodies on his shelves and was for a very fair price. He is the main stealers go to man up there. If your interested in his number I can supply!
Current:
2004 RS6 Avant, 1999 Range Rover, 2008 Iveco Daily (faster than the 6 hands down)
Past:
2008 Jaguar XK, 2006 S4 Avant, 2009 Mini Cooper S (Wifey's daily drive)
Firestarter
Post by Firestarter » Sat Aug 03, 2013 8:33 am
armyair wrote:Although I run an older C5 RS6 it had the RNS-E as standard.
Hey bud thanks for the info. Yeah his number would be good. Does he have a website as well?
Thanks again
Louie
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
armyair
Post by armyair » Sat Aug 03, 2013 8:51 am
Here is the link to his website:
http://www.tclsatnav.com/index.html
When you speak to him it's obvious he knows his onions.
Current:
Past:
PetrolDave
Post by PetrolDave » Sat Aug 03, 2013 10:18 am
armyair wrote:A really knowledgeable retro fitter from Manchester sourced and carried out the fit for me and had stacks of goodies on his shelves and was for a very fair price. He is the main stealers go to man up there. If your interested in his number I can supply!
That will probably be craigyb, s8craig (he has different name on some forums) - second that he's a top guy who really knows his stuff.
sync24
Post by sync24 » Sat Aug 03, 2013 12:57 pm
armyair wrote:When you speak to him it's obvious he knows his onions.
Craig did my 07 RS4 Avant RNS-E 2010+ upgrade, centre console swap out [to remove the cradle] and installation of my AMI into the glovebox. He charged me a a grand for the whole lot. He is mobile and will come to you or meet you somewhere convenient. He's a top bloke and as armyair said he deffo 'knows his onions' - Definitely recommended.
Firestarter
Post by Firestarter » Sat Aug 03, 2013 2:45 pm
Just emailed him. Im in the south so Im guessing we could meet half way. I'll see what he says :thumb: One thing (poss for PetrolDave) how difficult is it to have the TV set up and working? I have mentioned this to Craig and also if it can be done to have TV in motion set up. I had this in my M3 and its great for when you stuck on the M25 in a huge jam!!!!
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
PetrolDave
Post by PetrolDave » Sat Aug 03, 2013 4:56 pm
Firestarter wrote:One thing (poss for PetrolDave) how difficult is it to have the TV set up and working? I have mentioned this to Craig and also if it can be done to have TV in motion set up. I had this in my M3 and its great for when you stuck on the M25 in a huge jam!!!!
You have to fit the newer Audi digital TV tuner (which craigyb has done for several people), but the problem you'll have is that your glass most likely will not include the extra antennas and you most likely won't have the different antenna amplifiers needed by the OE TV tuner - so you may have to go the aftermarket route.
TV in motion is a problem with the 2010+ RNS-E - AFAIK there is not yet a widely available SW patch to enable it (although there is for the pre-2010 RNS-E). Again craigyb may have a solution for this.
Users browsing this forum: Google [Bot] and 243 guests
