RS6 C7 | 800+ BHP
Markp
Re: RS6 C7 | 800+ BHP
Post by Markp » Wed Feb 07, 2018 8:50 am
finance-nick wrote:
Tue Feb 06, 2018 11:00 pm
Markp wrote:
Tue Feb 06, 2018 10:54 pm
Are you planning on rolling road before and after to see what difference this makes?
I get the lower temps you are recording but does that actually translate into anything useful?
You got lower temps? Can you elaborate
Sorry, I meant I understand the fact that you are recording lower temps. My question is does this make any difference to performance - and are you going to measure that?
Mark
dasquade
Post by dasquade » Wed Feb 07, 2018 5:01 pm
Well atm i wasnt able to log under full throttle and summer temps but like pointed out, the more heat you keep inside the exhaust, the less will fill up your engine bay. So the less "extra heat" the air intake will pull and cold turbo will absorb. The difference wont be that much compaired to water injection but at least you battle the source. Heat soak in the long term kils performance and engine parts.
finance-nick
Post by finance-nick » Fri Feb 09, 2018 11:11 pm
dasquade wrote:
Mon Feb 05, 2018 8:13 pm
Cheers :)...hm that you mention, totally wrong material (lets heat through instead of blocking)!
Will remove it, leave stock or check for better material.
Meanwhile did one downpipe. Only +-30cm from trubo downwards, witch is the place were the tunnel starts to open up again and hopefully most heat finds its way outside...
Still gonna do the other downpipe and call it a night :).
Hopefully it was worth something...
How's it going, do you know the manifold temp before and after the wrap?
dasquade
Post by dasquade » Sat Feb 10, 2018 4:01 am
See on page 7 (before and after temps).
*manifold:
Before +-300°c
After +-80-90 (yesterday messured a 120°c).
Still havent full pushed the car, to slowly 'burn' in the isolation, but i think it is save to say all shielded parts temps are lowered at least 1/2 to some even close too 2/3 :).
finance-nick
Post by finance-nick » Sat Feb 10, 2018 9:58 am
*manifold:
Before +-300°c
Fantastic, are you experiencing any mild power improvements?
dasquade
Post by dasquade » Sat Feb 10, 2018 11:21 am
*manifold:
Before +-300°c
Not really, but it is winter so the cold ambient air is cooling the engine bay already. Guessing when summer comes we will see some gains...over unshielded :).
Golfather
Post by Golfather » Sat Feb 10, 2018 6:20 pm
Golfather wrote:
Sun Jan 21, 2018 3:56 pm
904PS
https://www.facebook.com/madnessmotorsp ... 986666052/
Audi RS7 4.0TFSI
- Madness Motorsport ECU
- Madness Motorsport TCU
- Turbosystems Hybrid Turbos Stage 2
- Aquamist Water Meth
- Forge Intercooler
- Eventuri Intake
- Milltek Full Exhaust System
Audi RS6 V8 4.0 TFSI GOGI Racing
917 h.p. 1318 Nm
- Eventuri Air Intake
- Akrapovic Exhaust System
- Water-Methanol Injection
https://www.facebook.com/gogi.racing/vi ... 105862019/
finance-nick
Post by finance-nick » Sat Feb 10, 2018 7:20 pm
904PS
Audi RS7 4.0TFSI
- Forge Intercooler
- Eventuri Intake
917 h.p. 1318 Nm
Great find, im learning fast that water methanol is an absolute MUST
dasquade
Post by dasquade » Sat Feb 10, 2018 9:10 pm
Still curious, afaik you need a custom tune that takes in account the methanol boost (basicly race fuel values i suppose). Just wondering, how the care behaves when it isn't beeing pushed and no methanol is injected (since our cars can't detect octaan levels).
My tuner hasn't answered me, in a way i would love to just water inject under boost/when IAT temps getting higher...and maybe seperate system or switch/tank with water/meth mix when wanted.
finance-nick
Post by finance-nick » Sat Feb 10, 2018 9:24 pm
Who told you the ECU’s can’t detect octane? Water will half IAT’s with or without a tune
dasquade
Post by dasquade » Sat Feb 10, 2018 10:07 pm
That is/was my general tought the ECU in our platform can't auto detect octane and adjust...
1. that is why apr for exemple offers several octane tune files (and you can swap afaik, but you need to load them into the ECU so it doesn't detect on the flow -> if injected).
2. with VCDS you can't read the octane level of fuel type.
That makes me curious how the car behaves when you don't use the meth all of the time and in my case it wouldn't make use the most of it (unless i tune for meth).
Fact is i been using a 1/10 mixture of bio ethanol (100%) in combination with my regular 98 gas. I don't know how equal ethanol and methanol are, in some ways simular (octaan boosters), both burn at lower temps and clean afaik.
The bio ethanol goes in my fuel tank (7l on full tank).
That is why i maybe should just focus on the water injection instead of water/meth.
finance-nick
Post by finance-nick » Sat Feb 10, 2018 10:33 pm
And you receive more power with ethanol right? That’s because your ECU will advance your timing due to the added octane, tuners will offer different tunes dependant on fuel to be mega safe, and maybe even adjust boost down on lower fuel quality to reduce knock
finance-nick
Post by finance-nick » Sun Feb 11, 2018 12:56 am
Found the turbo's i want
DXB_RS6
Post by DXB_RS6 » Mon Feb 12, 2018 6:42 pm
dasquade wrote:Still curious, afaik you need a custom tune that takes in account the methanol boost (basicly race fuel values i suppose). Just wondering, how the care behaves when it isn't beeing pushed and no methanol is injected (since our cars can't detect octaan levels).
I didn't change my tune after the aquamist instal. When the boost is low the meth is off and the car drives normally.
Sent from my SM-G955F using Tapatalk
dasquade
Post by dasquade » Mon Feb 12, 2018 6:56 pm
I see, cheers :).
Then i suppose the gains are 'minimal' and its first priority is cool things down, but nice non the less and that would be my goal aswell (some extra performance is always nice).
Users browsing this forum: No registered users and 99 guests
