Possible dead engine :( edit: new engine on way :)
Re: Possible dead engine :(
Courtesy car arriving tomorrow, at last after a lot of phonecalls a small piece of progress!
2019 Ara Blue RS3
Previous:
2014 Riviera Blue RS4
2006 Sprint Blue RS4
Previous:
yeah yeah yeah... more engine pics!
Rs4martin wrote:Courtesy car arriving tomorrow, at last after a lot of phonecalls a small piece of progress!
Good news, let us know what you get
Also maybe a slight acceptance by them that there is a valid claim here?
Currently :
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
Seat Ibiza excellence Lux!
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2017 AMG E class wagon
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2012 Audi RS4 (B8)
So they've given me a '62' plate s4. And I gotta say its a really nice car.
As for my car, seeing as I now have a vehicle to get me about I popped into the dealers this afternoon and the engine still isn't out, as far as I can work out they've just taken the sump off to investigate further but it looks as though a gudgeon pin has failed. They still don't know the reason why and its possible the piston is seized too. The next step is to take the engine out and check valves etc for further damage and a possible cause of failure. It's been 15 days now and I'm still no closer to knowing the reason, actually starting to really miss my car now.......
2019 Ara Blue RS3
Previous:
Previous:
But a B8 S4 should help though. Get it down to MRC for a remap and you won't want to give it back!
Gudgeon pin would fail if the piston was siezed in the cylinder.
I'm sure the b8 s4 will keep me going for now, probably not gonna do the remap, I'm guessing that would be frowned upon
Does anyone have any thoughts about this gudgeon pin? I don't really know much about them?
O Ye and he also said oil pump was all ok and bearings were all ok apart from the 2 conrods shown as per the previous photo.
2019 Ara Blue RS3
Previous:
Previous:
The loan car should take the edge off the pain for now.
Currently :
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2012 Audi RS4 (B8)
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2012 Audi RS4 (B8)
the gudgeon pin is what connects the conrod to the piston itself.Rs4martin wrote:I'm sure the b8 s4 will keep me going for now, probably not gonna do the remap, I'm guessing that would be frowned upon![]()
They are generally strong but the most likely (in my experience) point of failure should the piston sieze in the cylinder. The most common reason I've seen for a siezed piston is a complete failure of the oil spray systm on the cylinder. Either failed pump, lack of oil or oil breakdown. Piston rings can fail but generally cause an aweful mess and smoke out the exhaust.
But also, the pin can fail through damage in the crank or bearings... so need to see if it's the cause or a symptom. However the piston being stuck is quite telling.
I'm sure he said the gudgeon pin down by the crank, at the bottom of the conrod? Does that make sense?adsgreen wrote:the gudgeon pin is what connects the conrod to the piston itself.Rs4martin wrote:I'm sure the b8 s4 will keep me going for now, probably not gonna do the remap, I'm guessing that would be frowned upon![]()
2019 Ara Blue RS3
Previous:
Previous:
Yes because we all know the warranty company (audi) expressly discourages anyone from accelerating their $100,000 sports sedan , from 0-110 mph.Timster wrote: I think the warranty company may have something to say if your engine went bang.... what with all your strip-times plastered all over the internet, don't you ?
A car for which they boasted of nurburgring lap times, and the very car they used at audi experience track days, including fun drag racing sessions on the straights, all over the world.
Good thing you always keep yours below 45.
All warranties I have seen state that it'll be void if used for time trials. Drag strip runs would definitely count in that.
Then he is wrong there is only one gudgeon pin and it holds the piston to the crank. The pins at the other end are what rod cap bolts.Rs4martin wrote:I'm sure he said the gudgeon pin down by the crank, at the bottom of the conrod? Does that make sense?adsgreen wrote:the gudgeon pin is what connects the conrod to the piston itself.Rs4martin wrote:I'm sure the b8 s4 will keep me going for now, probably not gonna do the remap, I'm guessing that would be frowned upon![]()
@Rs4martin hope it all works out for you!
Have to say that I am well impressed with the information and knowledge provided here to the OP!
EFAadsgreen wrote: Then he is wrong there is only one gudgeon pin and it holds the piston to the ROD. The pins at the other end are what rod cap bolts.
Users browsing this forum: Google [Bot] and 182 guests
