Cam chain tensioners/pads removal and replacement guide
carrerasc
Re: Cam chain tensioners/pads removal and replacement guide
Post by carrerasc » Tue Feb 16, 2021 10:28 pm
Thanks for the reply and the warm welcome. :bigwave:
It's hard to reconcile what you are saying about the tools going on the cams OK with the kind of figures you are seeing.
I completely agree. Which is why I am on the struggle bus. The crank was locked using the locking pin. Not positive, but I think the tools came from eBay. I had to slightly bend the ends of the bar for them to be parallel to each other and fit on the rectangular washers. I have another cam bar ordered. I did not replace the rectangular washers. Is that really necessary?
Also, would the tension on the eccentric pulley play a significant factor in the timing? My understanding is that it is used to take up the slack and set tension (6NM CCW) on the belt while the damper pulley is in a locked position with the 5mm allen wrench. All this while the cams are locked in place with the bar and the cam sprockets are allowed to freely spin on the cam spindles. So the belt tension wouldn't have any affect on timing would it?
Dayton RS6 C5 Saloon - Weber intercoolers, APR diverter valves.
VW Corrado VR6 - VW Motorsport VSR intake, 268 cams, SS 2.5in exhaust, Koni adjustable suspension, Neuspeed sway & strut bars.
Post by Shoppinit » Tue Feb 16, 2021 10:51 pm
It shouldn’t as long as the tension is set with the sprockets free.
The rectangular washers don’t fill inspire much confidence in assuring alignment with their little square hole. Doesn’t take much imagination to see that some excessive wear/force could introduce some play.
Also maybe they’re not genuine and haven’t been made well. Seems like a stretch but not a crazy idea either. I’d definitely want OE for these parts. They’re not expensive.
Classik
Post by Classik » Tue Feb 16, 2021 11:30 pm
Confirmed no later than 3 days ago : this bar perfectly fits the BCY : BGS 8234 https://www.amazon.co.uk/BGS-Fixing-Too ... 846&sr=8-1
Mɐʇʇ
Post by Mɐʇʇ » Wed Feb 17, 2021 10:34 am
It's my experience that with new everything, it's still easy to end up with marginal numbers.
The square washers seem to rely on a bit of their galvanising to take up the clearances, so if you take the bar on & off a few times, the holes in the square washer the bar engages on wears and adds clearance. It's also possible that the LHS bank, which likes the cams to spring out of position, ends up loaded at full tolerance.
On my last cambelt job, I put it all together, bar on, pin in and so forth - marginal numbers.
Released it all, jiggled it a bit (bar on & pin still in) tightened it up - perfect numbers.
The plastic TDC marker on the front cover is also not very accurate.
And it's also possible for the TDC pin to go part way in, so you think it's spot on, but it's still a jog out. You have to make sure the pin is fully home - but not overtightened.
My job was arguably made worse last time since I had had the cams out - I think if it had been cams in, so both the cams and the crank were 100% undisturbed between belt off and new belt on, it may have been easier.
I suspect many of them are running with marginal numbers if the garage doesn't check in VCDS and just does it mechanically, but as long as your cam adjuster shoes are not worn, it should be possible to get the numbers pretty much bang on.
You can tell I just don't get on with the cambelt change on these cars. :biggrin3:
Classik
Post by Classik » Wed Feb 24, 2021 7:12 am
Just wanted to chime in to triple confirm the Vaico's are perfect replacements for the oem tensioners. Parts numbers are Vaico V10-4409 and V10-4410.
carrerasc
Post by carrerasc » Tue Mar 09, 2021 4:16 pm
Wanted to provide an update. So it turns out that the chain tensioner pads wore worse that I thought. After breaking it all back down I found the bank 2 top tensioner pad ends had broken off since last inspected. So I this time I dug deeper and removed the cams and tensioners on both banks and found more pieces of broken pads. The bottom pad on bank 1 was missing entirely and the chain was wearing into the metal on the tensioner. I thing this explains my readings I was getting on block 93. Further inspection of the tensioners shows that the screen to the oil inlet is missing or partially missing. A few questions for the group; 1. I can't find all the pieces to the bank 1 tensioner pad. I noticed a small passageway close to the tensioner, for oil I guess. Where are the rest of the pieces, would they have likely found their way down to the oil pan? 2. Looks like I am going to have to replace the tensioners and chains, screens missing and metal-on-metal wear. OEM vs anything else, I know to stay away from eBay? Someone mentioned the Viaco ones were working. Still holding up?
Mɐʇʇ
Post by Mɐʇʇ » Tue Mar 09, 2021 4:24 pm
Likely in the sump. Which is not hard to remove. Doesn't need a gasket, just a tiny slither of silicone.
Interesting the screen is missing on yours too. I wonder if this is a thing!
Mine has a Vaico adjuster in because I found one of my adjusters had ingested the screen. I even found the debris for it in the little hydraulic cylinder.
It's good - both banks (OEM with new shoes & Vaico) are exactly in spec and working 100% correctly.
allroadadi
Post by allroadadi » Thu Sep 05, 2024 1:34 am
I read through the DIY but not all comments. Did anyone bother to look in the service manual and clarify why it requires to turn the crankshaft 45 degrees to the left before camshafts removal? And it goes on to say that no pistons can be at TDC for camshaft removal…
Thanks!
ChrisH2017
Post by ChrisH2017 » Fri Sep 13, 2024 4:56 pm
Reading this thread with interest, my top tensioner pad has completely disintegrated, chain now sitting on the metal piece that the plastic pad should sit on. Misfires on allcylinders in that bank. What is the likelihood of bent valves? The chain seems fine, and I caught it relatively early (not much damage to the metal plate on the adjuster). Logic would suggest that assuming the chain hasnt jumped any teeth the over timing of the inlet cam would only be a few degrees (the difference due to the thickness of a worn plastic tensioner pad). Just trying to workout how far to tear into the engine....
TOPMAN
Post by TOPMAN » Fri Sep 13, 2024 8:16 pm
ChrisH2017 wrote:Reading this thread with interest, my top tensioner pad has completely disintegrated, chain now sitting on the metal piece that the plastic pad should sit on. Misfires on allcylinders in that bank. What is the likelihood of bent valves? The chain seems fine, and I caught it relatively early (not much damage to the metal plate on the adjuster). Logic would suggest that assuming the chain hasnt jumped any teeth the over timing of the inlet cam would only be a few degrees (the difference due to the thickness of a worn plastic tensioner pad). Just trying to workout how far to tear into the engine....
Does it look like this.
Been there done that.
ChrisH2017
Post by ChrisH2017 » Fri Sep 13, 2024 9:35 pm
Yes, similar.
ChrisH2017
Post by ChrisH2017 » Fri Sep 13, 2024 9:36 pm
Did you have valve issues?
TOPMAN
Post by TOPMAN » Sat Sep 14, 2024 6:49 am
ChrisH2017 wrote:Did you have valve issues?
No know valve issues, that engine ran quite fine. But it had other issues and was scrapped in the end.Image
TOPMAN
Post by TOPMAN » Tue Oct 15, 2024 2:08 pm
ChrisH2017 wrote:Yes, similar.
How you getting on Chris?
All fixed?
ChrisH2017
Post by ChrisH2017 » Wed Oct 30, 2024 10:39 am
Nope, I replaced the top adjuster pad by using the compression tool to get enough slack in the chain. All seemed to go well new shoe clipped into place. However engine ran fine at cold idle, but got rougher as it warmed up. Lots of checking later I found the adjuster seems to have now failed (maybe I over compressed it with the tool?) The lower spring loaded tensioner seems stuck and I have loads of slack in the upper part of the chain. Checked the cam alignments, also seems to support that. Better news is I did a compression test and all were at 175psi on that bank, so seems valves have not been damaged. I have a new adjuster to fit, just trying to work out if it is doable with the cambelt in place - I think it will depend if I can get enough movement of the cambelt metal backing plate to enable the adjuster to clear it.
