Front discs & pads
Mark-RS
Re: Front discs & pads
Post by Mark-RS » Sun Feb 03, 2019 12:43 pm
Any codes around ?
I'm needing rear pads......
Post by Shoppinit » Sun Feb 03, 2019 12:46 pm
carparts4less 17% off code:PAYDAY
Mark-RS
Post by Mark-RS » Sun Feb 03, 2019 12:53 pm
GSG50 Euro car parts. 50% off ends today :-)
Post by Shoppinit » Sun Feb 03, 2019 12:56 pm
They all make up the prices and discounts as they go along. Only way to compare is at the checkout stage.
Mumbbles
Post by Mumbbles » Sun Feb 03, 2019 1:14 pm
Hi all I've been looking at the rsq3 brake disc as they are the same size and thickness and same hub size but the discs for the rsq3 are a lot cheaper than rs6 c5 after market ones. Has anyone on the forum tried to fit these on a rs6 c5? Just a thought 💭
Post by Shoppinit » Sun Feb 03, 2019 1:47 pm
All depends on the hat depth.
Mumbbles
Post by Mumbbles » Sun Feb 03, 2019 1:58 pm
Checked all specs as they use same brembo brake system as the c5. just the rear ones are smaller than Rs6
The only difference I can see is shark fin on rsq3 rather than straight cut. The oem parts for the rsq3 is only £445 x2 with pads bargin
Mumbbles
Post by Mumbbles » Sun Feb 03, 2019 2:01 pm
Rear disc are just expensive as the front disc but found some on ebay with same spec as rears.
https://rover.ebay.com/rover/0/0/0?mpre ... 3314673658
Post by Shoppinit » Sun Feb 03, 2019 2:26 pm
Post by Shoppinit » Sun Feb 03, 2019 2:44 pm
RSQ3 front disks look like they are 390mm instead of 365, but they could be a good candidate for a big brake upgrade with C6 calipers. Maybe even the RSQ3 calipers, but I don't know anything about those.
Mumbbles
Post by Mumbbles » Sun Feb 03, 2019 7:46 pm
Post by Shoppinit » Sun Feb 03, 2019 8:28 pm
Pagid catalogue says 390, but it could be wrong.
Post by Shoppinit » Sun Feb 03, 2019 8:56 pm
Classik
Post by Classik » Sun Feb 03, 2019 9:06 pm
Great brand, the best around
Post by Shoppinit » Wed Feb 06, 2019 11:30 am
What did you get in the end and from where?
Users browsing this forum: HPsauce, srichards and 79 guests
