Brakes-vcds flag
steve2003rs6
Brakes-vcds flag
Post by steve2003rs6 » Mon Jun 10, 2024 2:15 pm
Anyone know what this means.
Re: Brakes-vcds flag
Post by Shoppinit » Mon Jun 10, 2024 2:20 pm
Hasn’t found the label file for your ABS controller.
Might be an issue with your VCDS installation.
Try updating to latest version after uninstalling the one you’ve got.
steve2003rs6
Post by steve2003rs6 » Mon Jun 10, 2024 2:49 pm
Cheers Ben. Will give it a go and report back.
HPsauce
Post by HPsauce » Mon Jun 10, 2024 4:07 pm
Are you using a genuine Rosstech cable? I've had communication errors like that in the past when using a cheap Chinese cable.
steve2003rs6
Post by steve2003rs6 » Mon Jun 10, 2024 5:29 pm
At £450 it better be a genuine cable.
Hpsauce. Last year my wife was “tidying up” and my unlimited vins cable went missing.
So I bought a new one.
Some time later the cable re appeared.
So I sold it on here.
But yes mate. It is a genuine unlimited vins cable and I am using the latest software release 24.5.
Recently had a brake fluid change. Also had new discs and pads fitted all round.So I don’t know if that has anything to do with it.
steve2003rs6
Post by steve2003rs6 » Tue Jun 11, 2024 10:13 am
VCDS uninstalled then reloaded.
Same problem exists
Brakes not recognised.
Post by Shoppinit » Tue Jun 11, 2024 10:24 am
Have you installed or updated your antivirus recently? Try installing your AV and/or firewall and seeing if you can connect then. Obvs don't use your laptop on the internet without those things running.
steve2003rs6
Post by steve2003rs6 » Tue Jun 11, 2024 10:26 am
If I go into control module then select abs brakes the brakes are recognised.
Post by Shoppinit » Tue Jun 11, 2024 10:29 am
Sounds like the autoscan settings are off then. Maybe you've checked or unchecked an option. Since you have a genuine cable, you can contact VCDS support on their forum, too.
srichards
Post by srichards » Tue Jun 11, 2024 10:31 am
Whenever updating a version of anything it's always worth checking through all the preferences to make sure they haven't been fiddled with. Annoys me endlessly when this happens.
steve2003rs6
Post by steve2003rs6 » Tue Jun 11, 2024 11:00 am
It was ok before I updated to version 24.5.
srichards
Post by srichards » Tue Jun 11, 2024 12:02 pm
Yep. They'll have changed something. It's just a matter of working out what. I'd email them and see if they have had other people encounter the same issue.
steve2003rs6
Post by steve2003rs6 » Tue Jun 11, 2024 1:41 pm
Cheers all.
Now onto Ross tech.
Users browsing this forum: No registered users and 26 guests
