Fuel pump upgrade
Sxcarmyboi
Fuel pump upgrade
Well this morning I set about swapping my fuel pump set up over. Nice easy job to be fair.
Taking out the standard single pump and cradle to exchange it for a twin in tank pump set up. This new set up is capable of supporting 980bhp so plenty for once I have built my engine
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
Re: Fuel pump upgrade
What about the main pump? Are you leaving that standard?
Sxcarmyboi
The main pump is getting pulled out as not need with this setup
Will just fit a fuel filter in its place.
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
Fair enough. Nice.
Wow that's a serious wiring connector there! Race/mil spec looking.
Sxcarmyboi
Oh yes nothing but the best with these parts
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
Mind Sharing some more details on the setup ??
RS Components sell lots of milspec connectors. I considered using some of them when I built my boat, but it was hard to justify the cost difference. Some of the 30 way ones I was looking at were mental money.
Sxcarmyboi
You need to check out Rene rumler from Germany that’s where I purchased it from
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
- anditsoundslikebells
Will Rene rebuild the motor?
Being in Holland, I have that idea in my head for some distant future.
RS6 C5 Avant 2002 Daytona Grey
TTH 620 - Wagner IC - OC.T 200cell&downpipes - DW400 pump - 034 TCU chip - FIS - B16 PSS9 - 034 control arms - H&R ARB - OZ Superturismo
Looks like he has a good solution for the pita maf setup. Too bad he's on the other side of the world for me
Sxcarmyboi
He does do engine builds. Although he’s not building mine.anditsoundslikebells wrote: ↑Sat Feb 11, 2023 8:17 pmWill Rene rebuild the motor?
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
Sxcarmyboi
I have got his 3” Maf too for my build
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
Sxcarmyboi
Today I finished off my dual in-tank fuel pump set up. Running both the outlet hoses down to where the secondary fuel pump is/was housed. Then into a 3 way connection to a new bigger fuel filter then onto the standard under car fuel line.
Running this dual fuel pump setup means I no longer require the external fuel pump. So I have removed all this and replaced everything in that area with just one bigger fuel filter.
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
Users browsing this forum: No registered users and 291 guests
