How much difference is there
First spring drive out joys
- Human Joist
Re: First spring drive out joys
Didn’t realise there was a 4s.
If it's not too late, it's worth getting the 4S. I remember seeing a review where they compared them. There was a difference, but not the kind of difference you'd get between them and, say, Pirelli PZeros.
Steve2003rs6
Had me wondering which ones I had fitted so went out and checked. Pilot sport 4S
Currently on 255x35x19
However the 255 does not provide any protection for the rims. The rims are 19x9j et35
When they come up for renewal was considering going to 265.
But I haven’t looked in to it too much as the tyres on at the moment are fairly new.
- Human Joist
It was too late. They were just fitting them. Found out the tracking issue. A seized bolt for rear toe. According to them has been like it for ages so they clearly didn’t adjust it last year and kept their mouth shut. The other place have refused to honour their work. So a new rear tie rod and bolt should sort it so I can track it correctly this time
Well, that review should reassure you that the PS4 is still pretty good.
I wouldn't. It'll change your rolling radius. Just avoid curbs.steve2003rs6 wrote: ↑Wed Apr 14, 2021 3:14 pmThe rims are 19x9j et35
Steve2003rs6
Hi shopp. Yeah having just had my ally’s fully refurbed and diamond cut after curbing them. I was just wondering if I could get them a bit of protection.
Will leave them on 255 as you recommend. Your knowledge is far superior to mine. Thank you for your advice.
- Human Joist
Any where suggested for getting tie rods online ?
Steve2003rs6
Have you tried eurocarparts.
Unit 20 supplied and fitted mine when I had the pss9,s installed.
- Human Joist
Online their website is crap. Will pop in tomorrow.steve2003rs6 wrote: ↑Wed Apr 14, 2021 8:17 pmHave you tried eurocarparts.
Steve2003rs6
Similar to yours. Mine were seized and could not be undone. So just had them replaced followed by tracking adjusted.
You could also try carparts4less
- anditsoundslikebells
I also have the P-SP 4 S 255/35ZR19 following Shop's advice.
I have a wider rim at 9.5 x 19ET40.
I've also been considering switching to 265 when the time comes.
Interestingly when I check on will-they-fit there is no difference in diameter using the 255/35 tyre on a 9.0 vs 9.5.
In my mind this can't be right?
Also, if I were to switch to the 265 I'd get the below difference.
Would this in any damage the vehicle?
RS6 C5 Avant 2002 Daytona Grey
TTH 620 - Wagner IC - OC.T 200cell&downpipes - DW400 pump - 034 TCU chip - FIS - B16 PSS9 - 034 control arms - H&R ARB - OZ Superturismo
- IchBautAuto
Exactly. Also have to remember the knob on the front suspension upright and clearance.Shoppinit wrote: ↑Wed Apr 14, 2021 3:37 pmI wouldn't. It'll change your rolling radius. Just avoid curbs.steve2003rs6 wrote: ↑Wed Apr 14, 2021 3:14 pmThe rims are 19x9j et35
When they come up for renewal was considering going to 265.![]()
Steve2003rs6
Many thanks guys. Will definitely retain the existing set up.
Users browsing this forum: No registered users and 200 guests
