Engine Fault - Camshaft Position Sensor - Ideas?
Hi All,
I've had the engine management light come on a couple of times now, it's always about a mile from home after starting the car from cold.
I hooked up to VCDS last night and pulled the following info;
Address 01: Engine (------CFSA) Labels: 079-907-560-CFS.clb
Part No SW: 8T2 907 560 E HW: 8T1 907 560
Component: 4.2l V8HDZ / H04 0003
Revision: NAH04---
Coding: 1225003225A6000A2000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM42FSI0118T2907560E 001002
ROD: EV_ECM42FSI0118T2907560E.rod
VCID: 3E7502F0A13DAEB1DB-806A
2 Faults Found:
9032 - Camshaft Positioner (Bank 2 Exhaust)
P000D 00 [096] - Slow Response
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 39603 km
Date: 2017.04.15
Time: 08:28:01
Engine speed: 1374.00 /min
Normed load value: 16.5 %
Vehicle speed: 63 km/h
Coolant temperature: 45 °C
Intake air temperature: 8 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.418 V
Unlearning counter according OBD: 37
Engine status-Bit 0: 3
Engine oil temperature: 16.2 °C
Engine operating condition: Idling
Engine operating condition-Test_Program_Channel 87: 5
Driver-side belt buckle status-Bit 0: 104
Current system status: SYC_DRIVE
Current system status-Test_Program_Exe Con State 02 UBYTE: 4
4363 - Brake Booster Pressure Sensor
P0556 00 [096] - Implausible Signal
Readiness: 0000 0000
any ideas what could cause this fault?
Just taking the car in for a service so I'll ask Audi to report too.....
Revision: NAH04---
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 39603 km
Date: 2017.04.15
Time: 08:28:01
2006 RS4 Avant - Carbon Clean, Intake Ports Polished, HF Air Filter, MRC Remap
1998 Toyota Supra 3.0 TT - de-cat, bleed valve, UK Spec Brakes, HKS Springs & CW Dampers, Goodridge Lines, Pagid Pads & 360 RWHP
1990 Toyota Supra 3.0 T - de-cat, HKS Boost Controller (1.4 bar max), used as a daily drive for 110k miles on original turbo!
198x Granada 2.8i Ghia X - Can't remember the exact year - but a great car!
Re: Engine Fault - Camshaft Position Sensor - Ideas?
Sorry I know this is WAY out of date... I have the same code and wonder if you recall what the issue was. TIA!
Bob, Mark / anyone else that may be able to help
Dont suppose either of you found a resolution to this fault code?
I'm getting the same issue. If I drive using very little throttle from cold, after a mile or two it throws an engine fault and limits to 6000rpm. Engine light and limit resets shortly after getting warm.
Plugged into VCDS this morning and it has fuel pressure and random cyclinder missfire issues also. Its recently had a major service at Audi, I didnt mention it when it went in for a service (it's been happening for about 3 months intermitantly), just to see if Audi would bring it to my attention. They didnt, which I personally think is awful, you pay a K for a service and they dont even scan your car for faults and raise it with you!
VCDS
Self-Diagnosis Log
Sunday,02,June,2019,11:46:25:16781
Page 2
VIN: WUAZZZ8KXEA901906 License Plate: R5RXW
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Revision: NAH04---
VCID: 3E76AAC8A13638BFA3-806A
8 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 104098 km
Date: 2019.05.28
Time: 06:18:15
Engine speed: 2046.00 /min
Normed load value: 17.6 %
Vehicle speed: 49 km/h
Coolant temperature: 54 °C
Intake air temperature: 11 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.559 V
Unlearning counter according OBD: 26
Engine status-Bits 0-7: 3
Engine oil temperature: 19.5 °C
Engine operating condition: Part. load
Engine operating condition-Test_Program_Channel 87: 6
Driver-side belt buckle status-Bits 0-7: 138
2638 - Low Pressure Fuel regulation
P310B 00 [032] - Fuel Pressure Outside Specification
9039 - Camshaft Positioner (Bank 2 Intake)
P000C 00 [096] - Slow Response
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 103324 km
Date: 2019.05.21
Time: 06:58:53
VCDS
Self-Diagnosis Log
Page 3
Engine speed: 1372.50 /min
Normed load value: 16.9 %
Vehicle speed: 33 km/h
Coolant temperature: 55 °C
Intake air temperature: 18 °C
Voltage terminal 30: 14.300 V
Unlearning counter according OBD: 8
CAN status - engine control module-Bits 0-7: 0
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 4
Cruise control switch actuation-Bits 0-7: 0
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [032] - -
10595 - Cylinder 5
P0305 00 [032] - Misfire Detected
10596 - Cylinder 6
P0306 00 [032] - Misfire Detected
10597 - Cylinder 7
P0307 00 [032] - Misfire Detected
10592 - Cylinder 2
P0302 00 [032] - Misfire Detected
VCDS
Self-Diagnosis Log
Page 4
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8T0 927 156 J HW: 0B5 927 156 K
Component: 0B5 42 FSIRdW H02 0003
Revision: --H02---
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001015
ROD: EV_TCMDL501021.rod
VCID: 4482D820CFDA5
VCDS
Self-Diagnosis Log
Page 2
Revision: NAH04---
8 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 104098 km
Date: 2019.05.28
Time: 06:18:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 103324 km
Date: 2019.05.21
Time: 06:58:53
VCDS
Self-Diagnosis Log
Page 3
P0300 00 [032] - -
10595 - Cylinder 5
10596 - Cylinder 6
10597 - Cylinder 7
10592 - Cylinder 2
VCDS
Self-Diagnosis Log
Page 4
Revision: --H02---
Coding: 000001
VCID: 4482D820CFDA5
Hydraulic variator was culprit on Marks car. Engine out to fix.
I had this issue, cam position (inlet) slow response. Cured by replacing cam control actuator and perform oil change. Job was 3hrs, didn’t require engine removal. The actuator works on oil pressure, it’s definately worth changing oil if this is your issue.
Panther Black RS4 B8
- Boredofthis
Hey, did you do the work yourself on this? Sorry to drag up old thread. I have similar code with exhaust bank sensor. Wondering how easy it is to swap sensors to fault find. TIA
2014 RS4 Avant Ibis White Black Edition on Titanium grey 20" V-Spokes
No I got it done under warranty as I had a warranty on the vehicle when I bought it from the dealer. The bad news is the fault came back and is still intermittent. Some times it’s registers sometimes it doesn’t. It’s quite annoying but can be cleared by a restart of the motor. Lived with it for over 2yrs now.Boredofthis wrote: ↑Thu Nov 04, 2021 5:59 pmHey, did you do the work yourself on this? Sorry to drag up old thread. I have similar code with exhaust bank sensor. Wondering how easy it is to swap sensors to fault find. TIA
- Boredofthis
Thanks @RS4GCI for the reply. I have new actuator on order anyway so will change that. I wondered if it might be to do with electrical supply, perhaps after cold start battery might be a bit weaker if the actuators are stiff. Just seeing as it only does it from cold, never once the car has been started already.
It sounds a very similar issue to mine. Only on cold start it occurs and light throttle. If I let the motor warm up to the first line on temp gauge before setting off it doesn’t throw the EPC light. Never occurs when the motor is warm. It’s really annoying as it doesn’t affect the performance of the motor other than limiting revs to 6k if it does occur but it can then be cleared by a restart.
Users browsing this forum: No registered users and 154 guests
