ABS sensor fault
ahoooga
ABS sensor fault
Post by ahoooga » Thu Apr 18, 2019 7:55 pm
I've had the abs light come occasionally recently, no set pattern to it and when it will come on. Turn ignition off and back on and it stays off for a day or two.
Did a scan with VCDS and got
00283 - ABS Wheel Speed Sensor; Front Left (G47)
30-10 - Open or Short to Plus - Intermittent
I'll put a new one in to see if that cures the issue, however, Stealers want £188 +vat !
Looking for recommendation where to buy from or does another VAG car's fit ours ?
Re: ABS sensor fault
Post by Shoppinit » Thu Apr 18, 2019 8:06 pm
Oh dear. I’m afraid it’s probably not the sensor but the ABS controller. Swap the left and right sensors before splashing out on a new one. If the fault remains on the left then it’s the controller (or the wiring but most likely the controller).
ahoooga
Post by ahoooga » Thu Apr 18, 2019 8:57 pm
Good call on changing them over side to side first Shop , Thanks
srichards
Post by srichards » Fri Apr 19, 2019 9:05 am
Are the controllers still available from Audi at some eye watering cost?
Post by Shoppinit » Fri Apr 19, 2019 12:18 pm
I believe Audi only sell the whole pump with controller.
Friend of mine bought a controller for his E34 BMW from Autodoc which looks identical.
It’s a Bosch part. There was a thread a couple of months ago with part numbers. I’d like to know whether any Bosch 5.7 module can be used.
Users browsing this forum: 111marc111 and 131 guests
