SS+ Owners, Help Req
Could somebody with SS+ measure their front ARB for me please?
After a bit of research it appears pretty much all A4’s including RS4’s with or without SS+ have a 29mm front ARB, yet mine is 31.5mm. Maybe it’s 29mm before it’s powdercoated or someone’s stuck a thicker one on but it looks factory.
Thanks in advance
Thanks in advance
Only the rear arb is different on ss+
The front are the same 29mm
Rear SS+ 22mm
Rear Non SS+ 20mm
Ss+ sits 10mm lower at rear
Rear SS+ 22mm
Rear Non SS+ 20mm
Re: SS+ Owners, Help Req
2.5mm of powder seems a lot. Got a picture of it by any chance? Preferably part number and maybe the end bit?
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
My H&R arb’s on my previous car were dark blue
If yours are bingo
If yours are bingo
Pule, I thought 2.5mm of powder coat was a lot but it’s only 1.25mm per side so possible I suppose.
As for a part number, that would have made life a lot easier but the Sticker fell if ages ago! It was definitely an OE number and it looks OE to be fair, black with female threaded ends.
Will measure mine tonight for you
That’d be great if you could James
Mine is 31.5 also.
Problem solved
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Threaded should be OE. Possibly the front Hotchkiss bar is threaded too, can’t remember but doesn’t sound like you have that one anyway. Also think that one is 35mm (could be wrong).Daytona wrote: ↑Sat Dec 29, 2018 10:49 amPule, I thought 2.5mm of powder coat was a lot but it’s only 1.25mm per side so possible I suppose.
Not unless we both are, mine still has the audi part number Sticker on too.
Users browsing this forum: lugars4 and 238 guests
