Hi!
I have sold my B7 RS4 (loved it, but time was right) and just picked up my 2012 RS5
In Denmark where I live, its a good idea to use winther wheels/rubbers and I have a set (19inch) i used for the RS4 - but will they fit the RS5?
Advice is much appreciated.
Best
Mikael
RS4 wheels on a RS5
Re: RS4 wheels on a RS5
The B7 RS4 wheels have a centre bore of 57.1mm but the RS5 has 66.6mm. So you can use RS5 wheels on a B7 why using a spigot to reduce the size but you can't use B7 wheels on an RS5 as the centre bore will be too small.
However, I'd be surprised if you can't buy the same design wheel with a 66.6 centre bore; maybe not with the same deep style but some flatter ones.
Thanks - off to the wheelshop then
Hey Mike, i've got a question, I found nice rs5 wheels, but i'm not sure will they will fit over ceramic brakes. Wheels spec: 19x8" Et 26.MikeFish wrote: ↑Tue Sep 15, 2015 7:35 pmThe B7 RS4 wheels have a centre bore of 57.1mm but the RS5 has 66.6mm. So you can use RS5 wheels on a B7 why using a spigot to reduce the size but you can't use B7 wheels on an RS5 as the centre bore will be too small.
Thanks in advantage!
Nice 3 year old thread revival!
Sorry, can't help though; I don't know anything about the ceramics brakes or those wheels.
Thank you anyway
