Can someone explain stall speed to me please
Hi chaps
As the title say I’m clueless to what this means!! The reason I’m asking as I’m looking at uprated T/C from advance automotion in the states and they have 3 types with different stall speeds.many thanks
Re: Can someone explain stall speed to me please
Stall speed would be the RPM at which the TC limits the engine speed, if the transmission output is prohibited.
2004 Audi RS6 Avant Plus #283
It’s how fast the engine can spin with the transmission in gear but with the car stationary, simplified to the extreme.
Google is your friend:
In general, the desired stall speed should be 500-700 RPM below the engine RPM at peak torque. This ensures a margin for application for the torque converter to take off. You don’t want to have to floor your gas pedal and wait a few seconds for your vehicle to move. Think of it as a balancing act.
- Weiß-sechs
- 5th Gear
- Location: Everywhere & nowhere baby, that's where I'm at...
....none of which will help you in deciding between 2200 & 2800 rpm stall speeds
Except the line from BenR1...Weiß-sechs wrote: ↑Thu Aug 16, 2018 2:39 pm....none of which will help you in deciding between 2200 & 2800 rpm stall speeds
"In general, the desired stall speed should be 500-700 RPM below the engine RPM at peak torque."
- Weiß-sechs
- 5th Gear
Yeah, I saw that with a Google search too...means jackshiz without a dyno graph
OP, best get some dyno time then, find out the rpm for your peak torque
I think on most of the Dyno plots I've seen for these beasts once tuned peak torque is around 3200RPM, so I would go for the lower stall speed on the box.
Of course, if you are planning loads of high rev launches then go for the higher one.
Dave
Dave
Why don’t you contact them and ask for their opinion? If not I’m sure your competent mapper or MRC will be able to advise
When I had my ACE converter made the owner suggested a 200rpm higher stall speed which is what I went for. I'll be honest I can't tell the difference.
'muricans love it because it helps with launching at the quarters, y' all! Just keep it at stock stall speed. Also, in my research, apparently the TCU and ECU wouldn't make friends with a higher stall speed, that said, it seems Bilko hasn't had any issues.
Thanks for all the reply’s guys! Think I’ll stick with stock stall speed-just want something that’s going to last
Out of interest, do you mind me asking what this is going to cost ? Including postage and import duties etc ?
If i remember correctly it was about £535 all in. I was lucky and bought a used converter off the Americam RS6 forums and the guy sent it to ACE for me. This was a few years back when the pound was worth a <beep>.
Users browsing this forum: Marcin, Shoppinit, srichards, steve2003rs6 and 207 guests
