light and strong Audi R8 V8
Re: light and strong Audi R8 V8
+1, looking sharp
Tom some of your images have gone missing
Hi
Front there was also something to get, 1kg, see picture
Tom
Tom
Hi
So, RS5 manifold step two on R8 V8 engine.
With again revised intake camshafts, the V8 engine is likely to have 525-530PS next year.
Tom
Tom
I thought you'd have had some better tubulars made by now. That said, I guess there hasn't been any improvement on the previous OEM headers. Didn't Supersprint spend a truck load of time developing different sets that didn't flow any better nor make any more power? They did look beautiful, very Italian.
Hi
I do not know any exhaust manifolds from Superdprint for the R8 V8.
My goal was to take the short version of the RS5, because they allow a higher rated speed.
The old RS5 manifolds are too long.
Tom
Tom
- Shinobi675
- 5th Gear
Can’t believe you’re still going at this Tom!
Not sure if it’s good work or just wow ok then!
I’ll go with good work
Good work!
Good work!
Hi
The intake system of the R8 in its full size and in the modified version.
Tom
Tom
Hi
Here are a few pictures of how the four-inch air duct is installed.
In October of last year, I was on the roll to determine performance.
The last-mentioned optimizations have increased the torque.
Tom
Tom
So friends of tuning, the R8 body is maximally relieved and the V8 engine there is nothing more to optimize.
As a result, there is just another engine and that can only be the V10 engine.
A V10 engine is already in place and will be optimized for use in 2019 in advance.
Target is 670 HP and 630-640 NM torque.
Tom
Tom
Bloody Hell Fire Tom
Go for it
Go for it
I'm sure v10 was suggested awaaaay back in this thread.Covkiller wrote:Bloody Hell Fire Tom
Go for it
Good luck Tom
Sent from my SM-N950F using Tapatalk
About post 71 on page 5... back in 2014.bobededog1 wrote: ↑Thu Feb 01, 2018 10:15 amI'm sure v10 was suggested awaaaay back in this thread.Covkiller wrote:Bloody Hell Fire Tom
Go for it
Good luck Tom
Times are changing, thanks to the 4S Gen2
Tom
Tom
Hi Tom, IMO, it will be very hard to achieve 670hp/ 640nm with the stock fuel system unless you some how can manage to fit the Gen-2 version with double rail of fuel injectors.Speedr8 wrote: ↑Thu Feb 01, 2018 7:12 amSo friends of tuning, the R8 body is maximally relieved and the V8 engine there is nothing more to optimize.
Tom
The most I recon you can achieve with the stock fuel system is around 620ps/620nm.
Regardless, best of luck and glad you have finally decided to go with an V10
Hi @classba
If you have the knowledge that the R8 V8 injectors make more throughput than the V10, then you take these.
If the high-pressure pumps of the V10 Gen1 are too weak, then you take the amplified version of the free market.
Tom
Tom
Users browsing this forum: No registered users and 95 guests
