Hi Guys,
I've just received my 12mm squared Eibach spacers, however now need to add longer wheel bolts.
Does anyone know what length should be ordered when running the 12mm spacer setup?
FYI - This is with OEM PE 21's fitted.
Thanks!
12mm Spacers = What length wheel bolts?
Current Cars:
2018 991.2 GT3 - Carrara White
2010 997.2 GT3 - Carrara White (Sold)
1982 911 Carrera RSR IROC - White
2016 RS6 PE - Nardo Grey
2016 Audi A1 S-Line - White
Re: 12mm Spacers = What length wheel bolts?
Measure your standard bolts and add 12mm on
Hey J66kco totally agree.. And whilst common logic would say this to be the easiest method... unfortunately I am abroad and without access to the car. I was hoping to order and have arrive by the time I return.
Unless someone can tell me the standard lengths?
Current Cars:
These are what I used with a 10mm spacer. A 35mm thread length
I have 12mm spacers with the right length bolts at home but I'm abroad too. I'm sure someone can tell us the right length bolts before I get home next week.
Thanks do you know if it has extra thread or is bang on for the 10mm spacers you run?
Current Cars:
