new rs4 with problems , help please
white.akita
Re: new rs4 with problems , help please
Post by white.akita » Sat Jul 08, 2017 2:28 pm
If I apply vacuum to this pipe that goes down under the airbox I lose vacuum, is that normal ?
I am getting loads of vacuum to the inlet flaps and I'm not loosing any at all.
How can I get two conflicting fault codes that say the inlet flaps on bank 1 are both stuck shut and stuck open ??
Sent from my SM-G935F using Tapatalk
Jon_J
Post by Jon_J » Sat Jul 08, 2017 2:44 pm
It says intermittent, when was it last carbon cleaned? Is it getting stuck due to carbon build up?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
white.akita
Post by white.akita » Sat Jul 08, 2017 2:59 pm
i have no records of it ever being carbon cleaned, its done 106k miles.
when there is no vacuum in the system i can move the inlet flaps very easy with pushing my finger against the plunger, if i reconnect the vacuum pipe that plunger becomes rock solid and i can no longer push it.
i find it hard to believe it is actually getting stuck as it moves so easily when there is no vacuum applied.
white.akita
Post by white.akita » Sat Jul 08, 2017 3:02 pm
im starting to think its the selonoid at the front of the engine that controls the inlet flaps that is broken. do i have to take the bumper off to change it ?
white.akita
Post by white.akita » Sat Jul 08, 2017 3:43 pm
when i try to test the inlet flaps with VCDS all i get is VCDS constantly and quickly cycling between off and on, absolutely nothing happens to the manifold flaps even if i put my finger on them and try to push slightly. its like once the vacuum is applied the manifold flaps slam shut and never open.
white.akita
Post by white.akita » Sun Jul 09, 2017 12:01 am
Anyone help with this ?
rs user
Post by rs user » Sun Jul 09, 2017 2:32 pm
have you checked the sticky at the top of this section
gives a good guide how to check your flaps,solenoid etc and to use blocks 42 etc ...
white.akita
Post by white.akita » Mon Jul 10, 2017 12:28 pm
just a reply to say how i have fixed my issue, sick of reading posts where people have asked for help and not had the decency to reply with how they fixed the issue !
anyway my issue was the vacuum solenoid for the flaps at the front of the engine. it was a real pain to change due to limited space.
no more drc light.
rs user
Post by rs user » Mon Jul 10, 2017 4:24 pm
glad you got it fixed-better than having to take the manifold off thats for sure...
white.akita
Post by white.akita » Mon Jul 10, 2017 6:48 pm
thanks arthur for your help :)
yeah removing the manifold was the last thing i wanted to do, that or take it to a dealer !
ive also learnt quite a bit about the car which is always good.
Jon_J
Post by Jon_J » Tue Jul 11, 2017 8:03 pm
Good job
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Users browsing this forum: No registered users and 109 guests
