DIY B14's
Jon_J
DIY B14's
Post by Jon_J » Mon Jun 26, 2017 12:23 pm
Just trying to get a feel for it, can the DRC be removed and b14's fitted on the driveway? Anyone had a go?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
andyg72
Re: DIY B14's
Post by andyg72 » Mon Jun 26, 2017 12:32 pm
Dave H just done his
Personally I wouldn't I'd rather pay a professional to do it
But if you feel it's with in your range of diy go for it
pule333
DIY B14's
Post by pule333 » Mon Jun 26, 2017 2:28 pm
Yes it's straight forward. Car don't need to be on ramps. Image
Main problems are:
Pinch bolt on top front arms. (Of it never been out, be prepared to snap it)
Rear spring. (need spring compressor, royal PITA to remove)
Time. (I did mine in about 6-7 hour. +2h adjusting and I am no stranger with tools.)
DRC lines at rear. (I cut mine in to smaller pieces and just brute forced it) if you wanna keep them, subframe and fuel tank needs to be dropped)
RS4 B7 aka Vinnie
Jon_J
Re: DIY B14's
Post by Jon_J » Mon Jun 26, 2017 2:32 pm
Ah ok, might brave it then. Can I ping you if I have questions?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
pule333
Re: DIY B14's
Post by pule333 » Mon Jun 26, 2017 2:33 pm
Jon_J wrote:Ah ok, might brave it then. Can I ping you if I have questions?
Updated my reply.
Yes ofcource!! I have done it few times on B7s
Inc. snapping pinch bolts lol
RS4 B7 aka Vinnie
Jon_J
Re: DIY B14's
Post by Jon_J » Mon Jun 26, 2017 2:35 pm
Still, sounds like a challenge, I like a challenge. And time is something I have at the moment.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Jon_J
DIY B14's
Post by Jon_J » Mon Jun 26, 2017 2:37 pm
I'll have a look to see the difference between parts and having them fitted.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
pule333
Re: DIY B14's
Post by pule333 » Mon Jun 26, 2017 2:37 pm
Jon_J wrote:Still, sounds like a challenge, I like a challenge. And time is something I have at the moment.
Well it will be :) but nothing you won't be able to overcome. Just don't rush! Luckily you have 16h of daylight ;) I did mine when it was dark at 7 ;)
RS4 B7 aka Vinnie
Harris.
Re: DIY B14's
Post by Harris. » Sun Jul 16, 2017 10:46 am
Indeed I've just done mine , it can be done but a lot of messing around . No need to remove the top pinch bolt as you just pull the shock towards the arch and undo the arms . I removed all the under trays so I could remove the DRC lines , obviously in a garage up on a ramp is easier than being on you're knees on a garage floor !
I've had a headache with stopping this horrible knocking noise OSF over small bumps .it's a shame that bilstein didn't design their springs to sit in the top mounts like OEM as it took them 3 days to advise me you have to cut them along with there instructions that clearly state helper spring at the top when in fact you put it at the bottom as it's tiny compared to the main spring and it would never sit in the rubber mount correctly . So from reading many posts through Google there is a few owners with the same problem and most suggest new drop links which mine are or new front roll bar bushes , I just need to remove the under tray to measure the bar as there is 3 different sizes on the powerflex website
Also when refitting the top arms put the bolts back in the reverse order Audi did , this makes it really easy to change top arms etc as when removing the bolt the strut tower isn't in the way .also get new rear tops mounts , they are £30 and worth changing while the shocks are off .
Would I do it again ? Yeah sure it's a straight forward job but as I've commented above the springs don't sit true inside the mount I took the car to MRR Racing who said the same ,and southend Audi who said it's all fitted correctly and looks fine . This is the trouble I'm having eliminating the knock knock over SMALL bumps in the road from OSF only .
rs user
Re: DIY B14's
Post by rs user » Sun Jul 16, 2017 1:44 pm
small knocks seem to be an issue with the b14,i want to upgrade the cheapie jap coilovers on mine to something that gives a little more height..the sub £200 coilovers on mine dont knock etc and dont kick the car all over the road...but are just too low,there are folk who dont get issues with b14 too,but searching reveals lots with knocking at the front-poor design isnt something i would expect for a product "knocking" on a grand
Harris.
Re: DIY B14's
Post by Harris. » Thu Jul 20, 2017 9:24 am
It's to do with the collar on the strut which sits below the strut top and the coilover spring not sitting in the OEM mount correctly .
Users browsing this forum: No registered users and 386 guests
