DIY B14's
DIY B14's
Just trying to get a feel for it, can the DRC be removed and b14's fitted on the driveway? Anyone had a go?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Re: DIY B14's
Dave H just done his
Personally I wouldn't I'd rather pay a professional to do it
But if you feel it's with in your range of diy go for it
DIY B14's
Yes it's straight forward. Car don't need to be on ramps.
Main problems are:
Pinch bolt on top front arms. (Of it never been out, be prepared to snap it)
Rear spring. (need spring compressor, royal PITA to remove)
Time. (I did mine in about 6-7 hour. +2h adjusting and I am no stranger with tools.)
DRC lines at rear. (I cut mine in to smaller pieces and just brute forced it) if you wanna keep them, subframe and fuel tank needs to be dropped)
Main problems are:
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Re: DIY B14's
Ah ok, might brave it then. Can I ping you if I have questions?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Re: DIY B14's
Updated my reply.Jon_J wrote:Ah ok, might brave it then. Can I ping you if I have questions?
Yes ofcource!! I have done it few times on B7s
Inc. snapping pinch bolts lol
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Re: DIY B14's
Still, sounds like a challenge, I like a challenge. And time is something I have at the moment.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
DIY B14's
I'll have a look to see the difference between parts and having them fitted.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Re: DIY B14's
Well it will beJon_J wrote:Still, sounds like a challenge, I like a challenge. And time is something I have at the moment.
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Re: DIY B14's
Indeed I've just done mine , it can be done but a lot of messing around . No need to remove the top pinch bolt as you just pull the shock towards the arch and undo the arms . I removed all the under trays so I could remove the DRC lines , obviously in a garage up on a ramp is easier than being on you're knees on a garage floor !
I've had a headache with stopping this horrible knocking noise OSF over small bumps .it's a shame that bilstein didn't design their springs to sit in the top mounts like OEM as it took them 3 days to advise me you have to cut them along with there instructions that clearly state helper spring at the top when in fact you put it at the bottom as it's tiny compared to the main spring and it would never sit in the rubber mount correctly . So from reading many posts through Google there is a few owners with the same problem and most suggest new drop links which mine are or new front roll bar bushes , I just need to remove the under tray to measure the bar as there is 3 different sizes on the powerflex website
Also when refitting the top arms put the bolts back in the reverse order Audi did , this makes it really easy to change top arms etc as when removing the bolt the strut tower isn't in the way .also get new rear tops mounts , they are £30 and worth changing while the shocks are off .
Would I do it again ? Yeah sure it's a straight forward job but as I've commented above the springs don't sit true inside the mount I took the car to MRR Racing who said the same ,and southend Audi who said it's all fitted correctly and looks fine . This is the trouble I'm having eliminating the knock knock over SMALL bumps in the road from OSF only .
Re: DIY B14's
small knocks seem to be an issue with the b14,i want to upgrade the cheapie jap coilovers on mine to something that gives a little more height..the sub £200 coilovers on mine dont knock etc and dont kick the car all over the road...but are just too low,there are folk who dont get issues with b14 too,but searching reveals lots with knocking at the front-poor design isnt something i would expect for a product "knocking" on a grand
Re: DIY B14's
It's to do with the collar on the strut which sits below the strut top and the coilover spring not sitting in the OEM mount correctly .
Users browsing this forum: Google [Bot] and 362 guests
