A bit of bolster work
Re: A bit of bolster work
If anybody is ordering - use discount code "dw10" for 10% off your order.
Thanks.norman1979 wrote: ↑Tue May 23, 2017 10:12 amWow thats great. Did you use the filler? Or was that not needed?
Also,the second pic looks like the passenger side seat? Do you have an after pic of that?
I used the filler in one very localised part, it didn't really need it but I wanted to test it. All the photos are of the drivers seat. If using filler the supplied 1200 grit paper won't be enough.
2010 987 Cayman S.
Clio 172 Cup track car "Nicole" aka NV2 Sold
Clio 172 Cup track car "Nicole" aka NV1 - R.I.P
2007 Phantom black RS4 avant - with added ceramics. Sold
2006 Phantom black RS4 saloon. Sold
1990 Black Audi S2 (3B) - full engine rebuild. Sold
1981 Black Porsche 924 Turbo, rescued from under a tree and restored. Sold
dougle_turbo wrote: ↑Tue May 23, 2017 4:59 pmThanks.norman1979 wrote: ↑Tue May 23, 2017 10:12 amWow thats great. Did you use the filler? Or was that not needed?
Thanks bud. I purchased the kit earlier so I will have a go at it and post pics. I dont think the filler comes with the kit you mentioned so hopefully I wont need it
hows it holding up?
- SimonS4MTM
- Top Gear
I have a question. Did you apply any filler in your application?
I have a kit and looking to have a go in a few days.
CheeRS
CheeRS
It's holding up really well, it's blended in nicely.
I'll get some pictures up soon.
2010 987 Cayman S.
I did use some filler, but it wasn't actually required (I wanted to test it). The filler is merely there if you need to fill any holes. The best thing you can do is buy extra 1200 grit sand sand paper. It's the sanding down part that payed dividends for me.SimonS4MTM wrote: ↑Wed Jun 21, 2017 7:34 pmI have a question. Did you apply any filler in your application?
CheeRS
2010 987 Cayman S.
i just done mine waiting on it dryingdougle_turbo wrote: ↑Sat Jun 24, 2017 9:20 amIt's holding up really well, it's blended in nicely.
Have you watched the video in their website? It's really that easy.
I was concerned on the sanding as well, but it just smoothed out the leather. The dye and lacquer do the rest.
2010 987 Cayman S.
Here it is
I have, yep...
Unfortunately I'm not blessed with a whole lot of patience...
I've got some 1500 paper so might try that shortly... just do a bit at a time
ta
ta
looking good pat!!
cheers
cheers
2010 987 Cayman S.
ya i went 50/50 on the lacquer as thats what you done and looked good
Users browsing this forum: Majestic-12 [Bot] and 520 guests
