Rs4 B7 ECU Wiring diagram
Grandadg90
Post by Grandadg90 » Wed Apr 06, 2016 1:02 am
I have an electrical fault and my autoelectrician is wanting the wiring diagram for the ECU. I have searched the net but cant seem to find it.
Would anyone know where I could find one?
Any help would be appreciated.
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
R1RS4
Re: Rs4 B7 ECU Wiring diagram
Post by R1RS4 » Wed Apr 06, 2016 1:34 am
Hi mate,
Most people download Elsawin
I downloaded a couple of years back for free... It take a bit of getting around but it has all the wiring diagrams and everything you will ever need
Hope this helps you and your auto lecky :biggrin3: :blackrs4:
RS4 B7 Avant,2007
Surrey Sam
Post by Surrey Sam » Wed Apr 06, 2016 8:29 am
What's your symptoms? Someone here maybe able to help having experienced something similar.
Grandadg90
Post by Grandadg90 » Wed Apr 06, 2016 1:24 pm
Thanks for that, will have a look.
Currently the engine management light is on, have had the codes read. Manifold flap sensor (malfunction lower limit reached), knock sensor 1 & 2 (no plausible signal).
Therefore my autoelectrician requires the diagram to be able to find the required wiring.
R1RS4
Post by R1RS4 » Wed Apr 06, 2016 2:34 pm
Grandadg90 wrote:Thanks for that, will have a look.
You say you have had the codes read, after copy save, did the codes get cleared down and retried?
Cheers good luck
RS4 B7 Avant,2007
koolade9
Post by koolade9 » Wed Apr 06, 2016 5:48 pm
Doesn't sound like a wiring issue...looks more like one of the flap position sensors died (it should tell you bank 1 or 2 when you pull the code). The knock sensors are shared between cylinders (i.e. cyl 1 & 2 share 1 sensor). It may just be picking up noise from that area.
Grandadg90
Post by Grandadg90 » Wed Apr 06, 2016 10:32 pm
I had knock sensor 1 replaced and flap sensors swapped between bank1 and bank2 to see it was a faulty sensor.
After doing this the faults were still the same.
koolade9
Post by koolade9 » Wed Apr 06, 2016 11:33 pm
Grandadg90 wrote:I had knock sensor 1 replaced and flap sensors swapped between bank1 and bank2 to see it was a faulty sensor.
When looking in VCDS, are you able to see knock voltage from the other sensors? Specifically what happens when you pull up knock sensor #1?
Have you done a flap actuation test to ensure your flap solenoid & both flap actuators are working properly?
Grandadg90
Post by Grandadg90 » Thu Apr 07, 2016 2:46 pm
Yep flap actuators and solenoid are both working. Solenoid was replaced, recently. There is vacuum there.
Will have to check for voltage from other sensors.
PetrolDave
Post by PetrolDave » Thu Apr 07, 2016 6:10 pm
The area where the ECUs are mounted has a drain that often gets blocked, which can cause apparent electrical faults like this.
Have you checked that area?
Grandadg90
Post by Grandadg90 » Thu Apr 07, 2016 8:28 pm
That was my first thought so checked that and all was good. Thanks for your thoughts though.
koolade9
Post by koolade9 » Thu Apr 07, 2016 9:12 pm
I'm just hard-pressed to believe you actually have a wiring issue in a 10yr old car. It's more likely the nodes on one end or the other. Since you've essentially proved out the end nodes, how about the points in-between...Have you ever replaced any of your relays? I replaced my 614 relays in the ECU case while tracking down a different electrical issue and they have a new revision (644). May not be your solution, but food for thought...
Users browsing this forum: Google Adsense [Bot] and 132 guests
