RED_ROCKET wrote:Anyone got pics for a c7 RS6 steel setup or prices,
Got feedback from little devil but those prices don't seem special enough at the mo..
viewtopic.php?f=61&t=115447&p=740714#p740675
That's one of the only b8's I can say I like. Looks amazingRevolution wrote:Rs6 calipers bolted straight on and dust shields work fine also.
We needed some 4mm shims to get exact and we also have stainless steel lines fitted for added pedal feel.
Any questions re fitting pm little Glen
Excellent info!LittleDevil wrote:Some good info..
RS6/7 Steel Brakes 390/356mm NEW:
Front Calipers with Pads and Wear Sensors = 8.05kg each
Rear Calipers with Pads and Wear Sensors = 5.60kg each
Front Disc 390x36mm = 13.80kg each
Rear Disc 356x22mm = 7.25kg each
RS7 Ceramic Brakes 420/370mm NEW:
Front Calipers with Pads and Wear Sensors = 9.75kg each
Rear Calipers with Pads and Wear Sensors = 6.50kg each
Front Disc 420x40mm = 8.25kg each
Rear Disc 370x30mm = 4.55kg each
S6, S7, S8 Ceramic Brakes 400/370mm NEW:
Front Disc 400x38mm = 8.45kg each
Rear Disc 370x30mm = 6.75kg each
Kind Regards
unsprung weight is supposed to be that ratio IIRC - 10% off the unsprung is the 'same' as 10% of sprung. I'm sure I read that somewhere.Shinobi675 wrote:Definitely! How much do the standard wheels and tyres weigh? And hubs I guess. What's the percentage difference?
Fronts are 4kg difference ish.
That could be as much as 10%, quite a bit of unsprung weight difference! Imagining talking about loosing 200kg of the whole car...
That's compared to the C7's massive 420mm items. The B8/B7 have 380mm versions which are nearer 7.5kg each - B8 may weigh a little less as they use a different bell to the B7? Both 380mm ceramic setups also utilise a smaller calliper compared with the 420mm ceramic brakes.Shinobi675 wrote:Ap racing similar size. 9.3kg disks. So only 1kg heavier than the ceramics.
Only RS5 380x38mm is lighter, but RS6 4G CCB are really light compared to it's size.MikeFish wrote:It looks like the 420mm ceramics weight less than all the other front discs including smaller ceramics.
Users browsing this forum: No registered users and 156 guests
