Upgrading my knob
Dunkx
Upgrading my knob
Post by Dunkx » Tue Apr 15, 2014 11:58 am
Morning all,
My poor knob is well past its best. 85,000 miles of various people's sweaty hands on it have made it all worn and shiny. :-(
After reading somewhere on the web that the C6 RS6 knob will fit the C5 with a little modification, I now have one ready to fit that will match nicely the new steering wheel I have just had fitted. The challenge is, I can't seem to work out how to remove the current one. I've been told that you need to slide the silver sleeve at the bottom down, then pull out the silver button on the side and lift up. However for the life of me I can't get the silver sleeve to slide down, and don't want to force it for risk of breaking it.
Has anyone removed theirs? Is there a technique to it? Any tips appreciated.
D
Re: Upgrading my knob
Post by Shoppinit » Tue Apr 15, 2014 12:49 pm
You need to put the knob in D or N first. Can't remember which.
Also, make sure you put a cable tie behind the knob. If it pops back in, you're not getting it out again without destroying it.
Post by chunky79 » Tue Apr 15, 2014 12:49 pm
It will go down mate, have some weetabix and try tomorrow :thumbs:
Post by chunky79 » Tue Apr 15, 2014 12:53 pm
Shoppinit wrote:You need to put the knob in D or N first. Can't remember which.
Yup, bang on as usual, but the silver thing should cone down in any position ( I think )
Post by bam_bam » Tue Apr 15, 2014 2:17 pm
So much fnar. I must resist.
amanda1
Post by amanda1 » Tue Apr 15, 2014 3:19 pm
bam_bam wrote:So much fnar. I must resist.
Why?
It never usually stops you :bigblink:
950 nm torque!
Dunkx
Post by Dunkx » Tue Apr 15, 2014 5:22 pm
So - I managed to pull the silver thing down eventually. Initially tried some mole grips wrapped in cloth but hadn't released how weak the material was that the sleeve was made from, so have managed to scratch/dent it. :cry:
And then after trying the new knob and needing to make more modifications to the base of it, I pulled it off with such vigour that I wasn't able to stop the silver knob on the side popping into the body in time.
Clearly should have outsourced this task....
amanda1
Post by amanda1 » Tue Apr 15, 2014 5:27 pm
Dunkx wrote:So - I managed to pull the silver thing down eventually. Initially tried some mole grips wrapped in cloth but hadn't released how weak the material was that the sleeve was made from, so have managed to scratch/dent it. :cry:
Out sorce to audi.......that's what I do :bigblink:
950 nm torque!
Post by chunky79 » Tue Apr 15, 2014 5:34 pm
You might cryptic, but not many others do, and there's a reason why.
amanda1
Post by amanda1 » Tue Apr 15, 2014 5:44 pm
Maybe but audi are very capable of changing a knob be it a damaged one ;)
950 nm torque!
too hot
Post by too hot » Tue Apr 15, 2014 5:47 pm
amanda1 wrote:Maybe but audi are very capable of changing a knob be it a damaged one ;)
Yeah any time I visit I see lots of knobs :biggrin3:
amanda1
Post by amanda1 » Tue Apr 15, 2014 5:57 pm
See you get my meaning :bigblink:
950 nm torque!
Dunkx
Post by Dunkx » Fri Apr 18, 2014 11:49 am
So, for the benefit of anyone else who may suffer a similar bout of technical incompetence, I have at least managed to solve the issue of the silver knob popping back into the body of the stick. The solution? A kids' toothbrush. The sort with a small sucker on the end for attaching it to the sink. Just managed to generate enough suction to pull it out far enough to get a grip on it with my fingers.
Now just need to source a new silver sleeve thing...
D
Post by bam_bam » Fri Apr 18, 2014 4:31 pm
Dunkx wrote:So, for the benefit of anyone else who may suffer a similar bout of technical incompetence, I have at least managed to solve the issue of the silver knob popping back into the body of the stick. The solution? A kids' toothbrush. The sort with a small sucker on the end for attaching it to the sink. Just managed to generate enough suction to pull it out far enough to get a grip on it with my fingers.
D
Wow, I think that has just landed you on a paedophile register, somewhere. Now that I've quoted it I might be tarred (spelling?) with the same brush. Right, I'm off to sort that out now. Best of luck Dunk.
Users browsing this forum: Google [Bot] and 211 guests
