Are Extended bolts required with 8mm spacers?
Daytona RS
Hey guys, so my 8mm h&r spacers arrived today, but my question is; will the oem bolts have enough meat on them to grip spacer+rim or will I need to get longer bolts?
Daytona RS
Re: Are Extended bolts required with 8mm spacers?
Oh and was I supposed to get longer bolts in the kit?
yes need longer bolts
no not usually, do from virdee
who you get them from
Audi Pardner
I got extended bolts and extended locking nuts with my kit from Virdee
Misano Red B7 RS4 Avant. 20" Rotors. KW adjustable spring kit. 8 & 10mm H&R spacers. MRC Stage 2 remap. Pre-cat delete & x-pipe.
Daytona RS
Just think about how awesome it'll look when you get it done - it really does change the stance!
'56 ST220 (Sold)
'97 ST24 (Sold - loved lots)
'56 ST220 (Sold)
Daytona RS
Yup, will have to see where I can source some bolts asap.
Do you know what the length of the oem bolts are? Is it as simple as adding 8mm for the new extended bolts?
CellDamage
The OEM bolts have a 26mm thread length and yes as simple as that.Daytona RS wrote:Yup, will have to see where I can source some bolts asap.
- Virdee Autos
- Trader (Expired)
Bolt sets in stock if your still after some!
Virdee Autos ~ 07950-526592
Daytona RS
Hi Virdee where are you based?Virdee Autos wrote:Bolt sets in stock if your still after some!
ordered from Virdee came next day no problems at all,great service, only prob is you are in the states right?
- Bladerider
Well,
When I ordered my spacers from Virdee I also got bolts, locking nuts, coilover's, arb's,adjustable front arms, a twix and a tube of Bigboy lube !!
Although he did ask for the twix and the lube back !!!!
Hope it worked out for you and Raul mate
8mm spacers require appr. 35mm bolts (orig. bolts 27-28mm).
Daytona Grey B8.5 & Guards Red 981 / Ex.Audi RS4 B7 Sedan, Daytona Grey.
Daytona RS
A little bit further south... In South AfricaRick_RS4 wrote:ordered from Virdee came next day no problems at all,great service, only prob is you are in the states right?
Users browsing this forum: Google [Bot] and 414 guests
