Speed warning!!
Speed warning!!
I have the speed warning set to somewhere between 80 or 100 (i can't tell as I focus more on the road) but every time i kick down i get this warning for sometime and then disappear .. however, when i checked the speed warning settings in MMI i found it set to 0 ZERO! so how to disable this plz?? any other option somewhere?
Re: Speed warning!!
There are 2 limits, should both be on the same page. Check the other.
Re: Speed warning!!
I've checked and only one speed warning setting and other two for computer on-board ... any photos you have for the second option?
Re: Speed warning!!
Will have to check, I may be getting confused with my 911...
Re: Speed warning!!
Thanks .. I noticed today the limit at 120km/h ..
Re: Speed warning!!
I have checked again all MMI settings and nothing other that that single setup to set the warning limit to zero. I guess it need to be reseted by VAG? It comes at 120km/h and keep a warning signal for sometime on the DIS screen.
Re: Speed warning!!
Must be able to set it another way or cancel it.
If you press the chech button while engine is running you will se both mph limits come up
RS6+ C6 Saloon, Mamba Black, sold and still regretting it
Re: Speed warning!!
if you haven't sorted it out yet i can help you out, the IC must be re coded via VCDS to ROW, since it is a GCC car it's coded to Saudi Arabia region, therefore the 120kmh speed limit, ridiculous though as nobody here seems to respect that limit on the highway or for that matter most of the traffic rules
. Give me a shout when/if you're in Abu Dhabi or i will when i'll be in Dubai.
2004 RS6 by ABT, madly in love with it, RNS-E, ST coilovers, new TC, 19x9x29 RS4 B7 wheels, non-resonated Milltek w/blk tips, TBC....SOLD - but never to be forgotten!
2004 RS6 ebony schwarz, SE exhaust, 19'' rims - SOLD
'09 RS6 C6 - the great white - now, this means business!
Re: Speed warning!!
Thanks buddy .. i thought so too .. i tried everything even the check button to disable Speed limit 1 & 2 all but still its coming right at 130 km/h every time. So i guess it needs VAG .. I had the same in my C5 and had to take it to the agency to remove it .. will call u soon to meet in Abu Dhabi and let me know when you here in Dubai anytime
Re: Speed warning!!
Finally !! problem solved ... car had to be recoded via VAG to remove the speed warning at 120 ... thanks mike for help
Users browsing this forum: hartley1967 and 60 guests
