250hp odds is what you would expect from an S3 running standard exhaust and cats.DuncS3 wrote:No cats or exhaust. From my point of view I feel 250ish is actually fair enough in real terms but it punderperforms against other chips on the same day, for example on AMDs rollers (where they ask whats in your car) Pauls AMD car got 270+ bhp when mine got 251 bhp - big difference for two cars with remaps
Makes you want to change maps but ultimately I dont believe it is really worth changing because I dont trust anyone and then again whats a few hp amongst friends!
Dunc
Tuning, Dynos, Power Figures Moans etc....
Star Performance Misano Red RS4
548bhp 490lbft
548bhp 490lbft
Barry, can you check these Lambda/fueling readings with Vag-com as well? There are certainly measuring blocks for the lambda sensors.
Don't forget guys, we still have this thread where we are asking for any RS4 owners to do some logging on their cars - tuned or stock...
http://www.rs246.com/index.php?name=PNp ... ic&t=48119
when i get back from Hong Kong next week I'm going to invest some more time in logging mine and a couple of cars that are based near to me.
Running very similar boost to the MTM map 1.5bar peaking at 1.7. The boost wasn't the issue with the MTM map in my car it was the over fueling which inturn affected the power.Prawn wrote:Barry,
What sort of boost are you having to run to get that power ?
548bhp 490lbft
548bhp 490lbft
The main difference with the boost on the StarP map compared to the MTM one is when that peak of 1.7 comes in. The MTM map had a quick burst at 1.7bar lower down the rev range where as the StarP map actually bears a stronger resembelance to the standard RS4 map where the peak boost is higher up the rev range.
Graph attached - appologies for the crappy scan my scanner ain't up to much!
- Attachments
- 548small.jpg (49.19 KiB) Viewed 937 times
548bhp 490lbft
548bhp 490lbft
2 Large 100mph fans with more than sufficient ducting sooking in good cold east coast air! And a seperate ducted fan. Seen better but it does the job.VST wrote:also what kind of fan or coling system do Star run on there Maha dyno,is it the standard Maha fan?
548bhp 490lbft
548bhp 490lbft
Users browsing this forum: No registered users and 40 guests
