Headlamp washers
WillRS
Headlamp washers
Post by WillRS » Fri Dec 13, 2013 10:57 am
is it definitely possible to disable these through VCDS ?
I can't see they are overly helpful at the best of times (and make a mess) and since i've had my front end resprayed they obviously aren't quite adjusted right and now spray the entire front end of the car each time I use them (at low speed) which isn't very helpful !
there was an old post on this saying they could be disabled but nothing since and nothing definite
any help would be greatly appreciated
adsgreen
Re: Headlamp washers
Post by adsgreen » Fri Dec 13, 2013 12:34 pm
should be easy enough to plug the fluid cables.
I don't think they come on when the headlights are off so you should also be able to disconnect the solenoid that activates them (but could be wrong) by unplugging it.
You technically have to have them for Xenon type lights as dirt and crap on them makes the light sparkle and diffuse which can cause problems for other road users - it could be a potential MOT fail.
Rick_RS4
Post by Rick_RS4 » Fri Dec 13, 2013 2:40 pm
Why don't you adjust them. Washers are required if you have xenons
WillRS
Post by WillRS » Fri Dec 13, 2013 3:26 pm
yeah could adjust them - is it just a question of grabbing them when they pop up (i.e get someone else to activate) and adjust the jets ? or is there a "service mode" you can put them into ?
I know in theory you need them if you have xenons but the amount of washer fluid I am getting through with them activating when i wash the windscreen when its a bit dark outside (autolights) is crazy and makes a mess even if correctly directed hence the question.
PetrolDave
Post by PetrolDave » Fri Dec 13, 2013 6:18 pm
Rick_RS4 wrote:Washers are required if you have xenons
Not strictly true if you're talking about passing the UK MOT test.
IF headlamp washers OR headlight levelling are fitted THEN they must work, but (and it's a big but) If they're NOT fitted then that's not grounds to fail the MOT.
So on an RS4 which has headlight washers AND leveling factory fitted they have to work to pass the MOT, but if you retrofit Xenons to a car with neither headlight washers nor headlight levelling (like my Citroen C1) then all that's need to pass the MOT is that the headlights are correctly aimed.
Rick_RS4
Post by Rick_RS4 » Sat Dec 14, 2013 12:21 am
they work when the pump makes pressure which forces them out, will have to disconnect the pump supply, i think its a different pump for windscreen and headlights
gt2
Post by gt2 » Sat Dec 14, 2013 3:05 pm
I have the xenons fitted but have never even noticed mine working!. Either they just dont work or there is a way of disbling them. Do you need to be doing a certain speed in order for them to work and test them?
PetrolDave
Post by PetrolDave » Sun Dec 15, 2013 6:33 pm
gt2 wrote:Do you need to be doing a certain speed in order for them to work and test them?
No, they work even when stationary - but, you have to operate the windscreen washers for several seconds before the headlamp washers operate, the normal short burst won't operate them.
C17LJR
Post by C17LJR » Sun Dec 15, 2013 9:53 pm
Even when retro fitting you 'should' have the washers and levellers to be legal. Sounds like you've just got lucky with your tester Dave
2007 Daytona Grey RS 4 Avant
2013 Daytona Grey RS 4 Avant
PetrolDave
Post by PetrolDave » Mon Dec 16, 2013 6:59 pm
C17LJR wrote:Even when retro fitting you 'should' have the washers and levellers to be legal. Sounds like you've just got lucky with your tester Dave
Not this Old Wive's Tale again - this debate happens every few months on every car website I frequent.
Nothing to do with luck - read the MOT Testers Handbook - neither are required to pass the MOT (but if fitted they MUST work), it's very clear and unambiguous.
BTW both Xenon headlamps and DRL's are illegal according to the UK Construction & Use Regulations, but since EU Law overrides local law they are deemed legal in every country in the EU.
nij
Post by nij » Mon Dec 16, 2013 7:23 pm
It's a bit like if you have an illegal spare wheel, then you'll fail your MOT, but if you don’t have a spare wheel, then it's alright.
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
adsgreen
Post by adsgreen » Mon Dec 16, 2013 7:58 pm
http://www.partinfo.co.uk/files/MOT%20C ... ghting.pdf
But yes - current regs are ambiguous wrt to the EU rules
http://www.motinfo.gov.uk/htdocs/m4s01000701.htm
PetrolDave
Post by PetrolDave » Mon Dec 16, 2013 8:19 pm
Interesting, but here's what the actual MOT Inspection Manual says (I've added the emphasis):
MOT Inspection Manual wrote:Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system.
Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems. In such cases, the benefit of the doubt must be given.
Note use of the word "may" not "must" - that's the key point. Plus in the Method of Inspection it says:
MOT Inspection Manual wrote:Where HID or LED dipped beam headlamps are fitted, switch on the headlamps and check the operation of any headlamp levelling and cleaning devices fitted.
And in the Reason for Rejection column it says:
MOT Inspection Manual wrote:A headlamp levelling or cleaning device inoperative or otherwise obviously defective.
So taking all that together - you do NOT need to have either headlamp washers/wipers or self-levelling to pass the MOT, BUT if they are fitted they must work.
guffy
Post by guffy » Mon Dec 16, 2013 9:23 pm
My headlamp washers refused to work during my MOT last month and it failed on that alone.
Was an annoying cost, around £180 to supply and fit a new washer motor IIRC.
WillRS
Post by WillRS » Tue Dec 17, 2013 9:28 am
ok but back to my original question - can these be disabled via VCDS ?
i'd make sure they were enabled come MOT time
Users browsing this forum: Google Adsense [Bot] and 326 guests
