People with Revolution (Real) Carbon airboxes...
Youngben
Re: People with Revolution (Real) Carbon airboxes...
Post by Youngben » Sun Sep 08, 2013 9:03 pm
I will get more information on the 3 stage filter as im yet to email the guy i spoke to but i will drop him an email tomorrow and find out whats what and update this thread :beerchug:
Yanos wrote:Mine was running fine for about 1000 miles but then started getting a flat spot at 4-5k, ran diagnostics yesterday and got a Intake Manifold Flap Position Sensor 008224 error. Is this what you have Ben?
no thats something different mate maybe the air box flap or the flaps inside the the inlet itself?
Post by MikeFish » Sun Sep 08, 2013 9:37 pm
Firestarter wrote:Plus 2
induction ROARRRRRRRRRRRRRRRRRRRRRRRR :biggrin3:
Didn't you have yours fitted the same time as your exhaust? If so, how can you even hear it?
Oh, and plus whatever (lost count). I'd pay that much for either a lovely bit of carbon under the bonnet or for the induction roar so to get both it's a bargain!
Noyjatat
Post by Noyjatat » Sun Sep 08, 2013 10:03 pm
Louie had it fitted for a week before the rest of his upgrades Mike.
Youngben
Post by Youngben » Sun Sep 08, 2013 10:09 pm
I fitted the exhaust and thought it was loud (non res non valved) and then fitted the airbox and couldn't hear the exhaust any more lol! had so many positive comments about the noise!! people were actually trying to get in front of me on our road trip as it sounded so good lol! im waiting for a video from a play i had with a GTR in Italy! The dog cam was under his spoiler facing back so should make for good viewing and sound.
Firestarter
Post by Firestarter » Sun Sep 08, 2013 11:27 pm
No Mike I fitted it the day after I got the car home so I could enjoy the ROARRRRRRR, so its been on 3 weeks and 2 prior to the AmD tweaks.
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT :-)
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre :-)
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
Post by MikeFish » Sun Sep 08, 2013 11:29 pm
Oh ok. I only fitted mine the day before I got my exhaust done and wished I'd done it years ago!
Yanos
Post by Yanos » Mon Sep 09, 2013 10:05 am
Youngben wrote:I will get more information on the 3 stage filter as im yet to email the guy i spoke to but i will drop him an email tomorrow and find out whats what and update this thread :beerchug:
I removed the power flap and plugged the vacuum line. Could it be that it does not know what's happened to that? Is that something I can code out?
The roar from the intake is second to none!
RS4 B7 Misano Red Saloon / Black Optics / Revolution - Pipercross Carbon air intake / Carbon Clean / Black Rings / Lepsons Black Chrome Alloys
adsgreen
Post by adsgreen » Mon Sep 09, 2013 11:55 am
Double check the vacuum plug - if it's losing any then the flaps will slowly close. Their default position is closed and it needs vacuum to open then up.
If you have vag-com, then log the manifold "requested" and "actual" position. Requested will flip flop between two target values representing open and closed. As long as the actual is broadly similar it'll run fine. Otherwise you'll get a manifold position error.
Also caused by any other failure in the vacuum system (exhaust flaps, SAI, one way check valve under the manifold).
Finally - the airbox power flap is just a simple actuator with no feedback to the ecu.
adsgreen
Post by adsgreen » Mon Sep 09, 2013 11:57 am
As an aside, if there is a standard paper non oiled filter available then I'll definitely get one of them.
Yanos
Post by Yanos » Mon Sep 09, 2013 2:01 pm
Finally - the airbox power flap is just a simple actuator with no feedback to the ecu.[/quote]
Noted, I will check it all out and post results in a new thread. Thanks for the info mate.
So do piper cross offer a paper filter for this? Is there even such a thing as a paper cone filter?
adsgreen
Post by adsgreen » Mon Sep 09, 2013 2:18 pm
Iirc I think the Honda s2000 oem air filter was a paper cone type
Anees
Post by Anees » Tue Sep 10, 2013 12:31 pm
adsgreen wrote:Iirc I think the Honda s2000 oem air filter was a paper cone type
You are correct (as usual!) The S2000 does have an OEM cone paper filter.
Surrey Sam
Post by Surrey Sam » Tue Sep 10, 2013 2:24 pm
Whilst I'm not keen on oiled filters, I'd also be concerned about putting an undersized filter in there too. The S2000s filter would have been designed to flow enough air for circa 250bhp, I'd very much doubt that there was enough headroom in the design to flow enough air for 8 cylinders with 400+bhp.
I know that you can use ITG's tri foam filter without the recommended oil in environments where there is little dust. I remember reading something about oil and filters in their catalogue?
adsgreen
Post by adsgreen » Tue Sep 10, 2013 6:41 pm
Very good point on the sizing - it was just the only one I knew of and so at least they do exist :) (even if in the wrong size).
Dead easy to test though - just Vag Com log the maf with stock/oiled filter in up to 8k rpm. repeat with s2000 and see the difference.
Firestarter
Post by Firestarter » Sat Sep 14, 2013 12:04 pm
Hey Ben
Any progress or updates on this bud?
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Users browsing this forum: No registered users and 479 guests
