Key Recoding
Markmyatt7
Key Recoding
Spare key doesn't work so rang Coventry Audi and they said need to bring both keys plus car in for recoding. Cost £71 - really does it cost that much for 30 mins work?
Current Car: 2014 Nissan Quashqai 4WD (it's not my fault)
Previous Cars: 2006 B7 RS4 - Phantom Black
2010 BMW 123d Coupe M Sport
2004 Honda Civic Type R
2002 VW Golf 2.8l V6 4 Motion
Re: Key Recoding
That is expensive even for Audi, to give you an idea VW (same key type) usually charge just over £160 to SUPPLY and code a new key.
Does the old key start the car and then cut out immediately? If so then the transponder is the wrong one for the car (someone lost a key and bought another of eBay perhaps?).
If you can get the SKC read from the car (VAG-Tacho / VAG-Commander needed) then it can be coded easily with VCDS.
VCDS HEX+CAN owner - covers all VAG cars (PM me if you require VCDS coding in Kent)
Re: Key Recoding
Have you tried new batteries? What doesn't it do? You can program the locking yourself.
Markmyatt7
Key Recoding
Just doesn't open the doors at all.
Re: Key Recoding
Markmyatt7 wrote:Just doesn't open the doors at all.
So the car runs OK on that key? if it does then the transponder is coded and is fine.
Sounds like the remote just needs re-pairing with the car, put a new battery in it and re-sync it to the car (instructions are probably in the owners handbook, but a google search will find it as well …. B7 A4 remote sync)
Markmyatt7
Key Recoding
God I'm an idiot never even checked that. Just done it and car starts fine with spare key - just the central locking part.
HD
HD
Markmyatt7
Key Recoding
This is why I love this forum, saved myself £71. All sorted followed Page 75 of drivers manual and all is good and working - many thanks for your help
HD
HD
Users browsing this forum: Majestic-12 [Bot] and 88 guests
