Hi my rs4 b7 bonnet cable has broke from the front catch and I can't get the bonnet opened can any one help how to open the bonnet
Help!!!!!!!
Re: Help!!!!!!!
found this on a quick trawl might help but sounds like you might have to cut the grill
http://www.justanswer.com/uk-car/526y6- ... model.html
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Re: Help!!!!!!!
wouldn't rate your chances going from under the car - that article says it's tough referring to a 2.0lt car and there's feck all space left with the big v8 in there.
Where has the cable broken? At the latch end or the lever? If the lever you may be able to cut away at the sheath and use a decent pair of molegrips on the bit thats left.
If the latch end it's going to be tricky.
Re: Help!!!!!!!
ok, take it back.
http://www.audizine.com/forum/showthrea ... -open-hood
From below is the way to go. I guess a helper navigating from the front of the car helps too.
Re: Help!!!!!!!
Happend to mine while at Audi. The tech opened it by getting through the wheel arch If that helps
B7 RS4
Black Optics
20" A5 wheels
Milltek-non res-no valves
Black Optics
20" A5 wheels
Re: Help!!!!!!!
Looking at it there's definately a way to get to it from under... it looks like the latch moves from the passenger side to the drivers side.
Still a complate bastard though
Users browsing this forum: Majestic-12 [Bot] and 107 guests
