Gearbox life survey
jd_hants
Post by jd_hants » Fri Aug 27, 2010 12:22 pm
Failed/failing
1. Rupert (2004) Standard power, failed at exactly 60k miles
2. paulm (2002) mrc Stage 1 at 40,000 ish. tc failed 42,000 mls (going manual)
3. batty (2004) STD 61k, gearbox replaced at 57k, no fluid change prior to that.
4. paul23 - STD till 30k, gearbox service at 25k, failed TC at 26k. MTM remap at 30k and on 31k now.
5. Mooch - standard when bought at 20ishk but box started to slip around 22-25k, grizz mapped it and it failed fairly soon after, (it was actually hunting only) gearbox replaced by Audi and not done well- lost oil due to ALL sump nuts only finger tight- grizz sorted.. serviced at 40k all fine. TCU mapped and all ok until 80k. now running big torque and box does not like it. 89k. but still going well if handled with care!
6. skyegtb - New box at 25,000 miles was running MTM 535 then, not sure of failure (previous owner). Now 52,000 miles and been MTM 568'd at same time as box replaced. G/Box service at 40,000 miles, all good, no issues so far, smooth as silk.
7. w8pmc - had 2 boxes go during ownership. 1st at about 15K miles & the car was stock (had only owned it about 2 months) Soon after i had the car tuned to Sportec/AmD Stage 2-3 & was putting out over 560BHP & lbsft & the box (mapped during tune) was fine through to 40K miles when it failed again. Sold the car soon after that.
8. p3u - clutch packs and tc went due to loss of pressure in system at ~91k miles. Stock other then Milltek exhaust at the time.
9. Hartge (2004) MTM Stage 1 (ECU & TCU) @16k. First box failed at 35k, second at 49k
10. Golffather (previous RS6 saloon) 2003 - MRC Stage 1+, Milltek. Total failure at 54k miles.
11. GregRS6 2003 Bought it with a so called gearbox warranty at 84K. engine and box out again 86K
12. GardinerG (2003) Stock when gearbox went at 36k miles. West Tuned & touch wood all is fine at 63k. Gearbox Service in 2 weeks (fluid & filter etc)...
13. spurtle (2003) MRC Stage 1+, TC failed @ 50k miles. Will change ATF every 20k from now on.
14.Grizz-new box fitted at 80k , stage 2 car ..
15.Billiemapped new box fitted and remapped at 51k...
Never Failed
1. Dave (2003) MRC Stage 1+ at 80K, still going strong at 110K, box serviced at 80K
2. Gorwanvfr Standard power 39,000 mls still going strong (Never touched)
3. el_ringo (2003) STD until 55,000 mi (Oct08) CCode 1, a 'box service at 60,000 (Mar09) now at 75,000mi (Feb10)
4. CliveH (2002) AMD code since mid 06 55k, gearbox service at 60k (Oct06), still going strong at 90k
5. RS6Steve (2003) Standard 63K still okay (Gearbox full service 62k, No debris)
6.Shoppinit 75000 mls with no problems. ATF changed at 70k and will be at every service now. ATF was clear and clean.
7. Steve Cuz (2003) STD 77k, Gearbox ok, (2 gearbox services in 2009)
8. ecain63 - bought at 50k. MTM1 on ECU and TCU @ 51k. Box serviced every 20k since. Still tight as a Nunns chuff and hit 90k mark today.
9. RS6-4dr911 – 48k mi on original, MTM TCU at 35k, fluid changed at 40k, flushed at 46k, clean fluid on both, will flush every 20k hereafter, just now flashed ECU to Eurocharge Stg.1,
10. woodlum (2002) STD 48k, no probs and works fine, never been serviced, undecided as to service or not??
11. RS6_Dave (2003) Std til 27,500, then MRC Stage 1+ , box map with Service, not a glitch but only on 33k now...
12. MoRS6+ RS6plus, STD, 26k, original ATF, smooth as ice.
13. Bazza (2003) Oettinger remap on ECU/TCU @ 29K (2006) now 39k...fingers crossed all OK
14. Coullboy (2004) GregR1's old motor. Gearbox oil + Filter etc 57K(£360 Specialist cars Aberdeen) , seems to be fine. Engine Standard (59K now).
15. 500bhp (2003) Grizzed, CC Stage2 + TCU, Gearbox oil + Filter etc 95K. All fine
16. Knutts (2003), STD, 78k, no probs and never been serviced.
17. Robrs6 (2003) STD, 88K, Box serviced at 50K, still going strong.
18. C5NVS (2003) STD, 58k, owned since 55k and no clear evidence of service (FASH and considering Audi "lifetime" ATF stance, suspect no service), gearbox still drives like new.
19. Fizmo100 (2003) STD, 70k, Just bought, no apparent issues, but currently having a Unit 20 gearbox service just to be on the safe side!
20. jamesthecat (2003)STD 48k no probs but just waiting for atf oil from audi to service it.
21. jd_Hants (2003) Gearbox serviced 80K. MRC Stage 1+ @ 85K, 95K now
Condor24
Post by Condor24 » Fri Aug 27, 2010 7:26 pm
Failed/failing
Never Failed
22. Condor24 .. May 2003 .. 46,000 miles to date .. I think serviced by Grizz February 2009
:beerchug:
"Understated uber wagen speaks loudest'
2003 Avant Daytona Grey owned from new. 64k miles of September 2018. Bilstein shocks / Hotchkis AR / Brake upgrade
Audi RS6 C6 Avant MTM Stage 1 & Miltek Sold
Audi RS4 Avant B5 Sold
Audi S4 B5 Avant 6 spd Sold
Audi S2 Coupe 230 bhp 6 spd Sold
MoRS6+
Post by MoRS6+ » Fri Aug 27, 2010 7:56 pm
Just to add to this - keep a close eye on your transmission sump. Mine started to leak a couple of weeks ago (29.5k miles) and MRC just tightened up the sump bolts and all has been well since. But I dare say the ATF level will be slightly down from factory as a result. But I've been assured we are talking a miniscule amount. But I will be changing the ATF fluid soon anyway.
Post by Shoppinit » Sat Aug 28, 2010 10:25 am
It annoys me that in a car with sensors coming out of its wazoo, there's absolutely nothing to warn you about low ATF.
viffer
Post by viffer » Sat Aug 28, 2010 11:13 am
Failed/failing
Never Failed
23. viffer. Standard, 72K. Gearbox service at 42K (Camberley Audi)
mrmule
Post by mrmule » Sat Nov 20, 2010 2:34 pm
Failed/failing
16. mrmule: Box #1 failed at 68k. Regular ATF flushes by MRC. Standard ECU.
Never Failed
SOLD - Avus RS6 Avant|KWV3|Hotchkis ARBs|RNSE|HighTech interior|Solar roof|Double glazed|Vreds|Non res Milltek|Phaeton brake ducts
VW T3|Avo 70mm drop|Subaru EJ25 motor|Audi 200 turbo trans|996 brakes|Peloquin LSD|RJES exhaust
Ceveman73
Post by Ceveman73 » Mon Nov 22, 2010 7:11 pm
Mine's a Plus with 17k miles. One gearbox service under it's belt and no issues to report. ATF was fine that came out.
Mart.
iR8V10
Post by iR8V10 » Mon Nov 22, 2010 7:28 pm
Failed/failing
Never Failed
11. RS6_Dave (2003) Std til 27,500, then MRC Stage 1+ , box map with Service, MRC stage 2 @34k, no probs yet and just turned 40k.
Post by HYFR » Mon Nov 22, 2010 8:33 pm
Failed/failing
Never Failed
24. aka_dk (2004) STD, 103k, no problems, gearbox serviced at 101k
amanda1
Post by amanda1 » Mon Nov 22, 2010 8:40 pm
Mines original and as far as I can see no service/work on it 100,000 and tickled ;)
zip929
Post by zip929 » Tue Nov 23, 2010 1:44 pm
Failed/failing
Never Failed
25. zip929 (2002) STD, 98K, no service and no probs.
JCviggen
Post by JCviggen » Tue Feb 01, 2011 8:39 pm
Failed/failing
17. JCviggen (2003) Stock, TC is gone at 65k. Never serviced.
Never Failed
seanypeeps
Post by seanypeeps » Tue Feb 01, 2011 9:03 pm
Failed/failing
Never Failed
26.Standard.Full audi service history 2004 salloon.Gearbox fail at 39578K.
marv8
Post by marv8 » Tue Feb 01, 2011 9:09 pm
According to the reciepts supplied by glasgow audi mine had a new gearbox supplied and fitted at 39167 had a "repair" due to gearbox oil leak at 40469 (issue with replacement maybe as seems too few miles???)
Now at 49k and TC failed, swarf in gearbox so rebuild with uprated drum and new clutch packs (plus a few other bits)
Car standard as far as I know.
Did try the goodwill line with Audi but was fitted in 2007 so outside 24 month gaurantee regardless of miles - thanks Audi!
JCviggen
Post by JCviggen » Wed Feb 02, 2011 11:05 am
Put the last 2 posts into the list for better oversight. Have to say the failure rate approaching 50% with most cars not exactly high mileage should be considered an embarrasment for Audi.
Failed/failing
18. Seanypeeps Standard.Full audi service history 2004 salloon.Gearbox fail at 39578K.
19. marv8 had a new gearbox supplied and fitted at 39167 had a "repair" due to gearbox oil leak at 40469 (issue with replacement maybe as seems too few miles???)
Now at 49k and TC failed, swarf in gearbox so rebuild with uprated drum and new clutch packs (plus a few other bits) Car standard AFAIK.
Never Failed
981 Cayman GTS Gray/Orange.
My youtube
Users browsing this forum: asgor, Google [Bot] and 117 guests
