best way to remove rounded nut
scooby-tc
Post by scooby-tc » Thu Dec 30, 2010 2:48 pm
as title i have a nut that is virtually rounded,is there an easy way of removing it as space is quite tight
cheers
2003 RS6 Avant (NOW SOLD)
Blue_Thunder
RE: best way to remove rounded nut
Post by Blue_Thunder » Thu Dec 30, 2010 4:56 pm
You can get special socket tools which are made of hardened steel, the inside of them is a 'spiral of teeth'. You hammer the tool onto the nut/bolt, then as you start turning it anti-clockwise it bites in until the bolt finally starts to turn. Don't know the name of them, but Grizz used them on a nut i'd rounded.
tanoga
Post by tanoga » Thu Dec 30, 2010 5:12 pm
Try this
Blue_Thunder
Post by Blue_Thunder » Fri Dec 31, 2010 11:27 am
Those are the beasties!
Blue_Thunder
Post by Blue_Thunder » Fri Dec 31, 2010 11:34 am
Probably also worth mentioning that even these things do bite into the bolts, it's not so much that the bolt couldn't be used again (unless it's rounded of course!).
Return to “General Car Chat”
Users browsing this forum: No registered users and 157 guests
