BATTERY PROBS
2.7 V6 30v biturbo - 380 bhp
andnik
BATTERY PROBS
Post by andnik » Wed Jan 21, 2004 1:00 pm
Hi Folks,
Just got home from my 2 weeks at work and the [img]images/graemlins/rs4-button.jpg[/img] is totally dead.....not a peep! The battery has totally discharged......this is not the first time............................... do you all have the same problems or where should I start looking for the gremlin that is sucking my power!!!! [img]images/graemlins/29428-red4.gif[/img]NIK
Bushy
Re: BATTERY PROBS
Post by Bushy » Wed Jan 21, 2004 1:34 pm
Look for gremlins!
Basically standard Audi wiring should not draw any power, except for alarm system which should last longer that 2 weeks
Quite often it would be an after market alarm or tracker device not connected to the correct feed
I had the same thing last year with my car as I didnt use it for 6 weeks when my back was bad, in the end spent £150 on a gold topped sealed battery, much better especially all the audio etc in my car [img]images/graemlins/1syellow1.gif[/img]
Can't beat a bit of boost!
NigelJ
Re: BATTERY PROBS
Post by NigelJ » Wed Jan 21, 2004 2:36 pm
I've has this twice. First time I got a new battery under warranty and last time, just a few weeks ago, I just charged the battery & its been ok since but I now carry jump leads in case. I suspect its something to do with the alarm system but I'm not sure. However I only left the car a few days not 2 weeks.
NigelJ
Taipan
Re: BATTERY PROBS
Post by Taipan » Wed Jan 21, 2004 3:04 pm
I have the same problem on mine, keeps dying after one-two weeks of parking.
I'm about to swap the batteries between the RS4 and the Passat to see if it continues (provided they can be swaped).
In any case, I do have several addition components like the GPS Immobilizer (as all S and RS cars now sold by Audi France have it standard).
Btw, my car was made in July 2001 so that's about 2.5 years of battery life.
Eric
- RS4 V6 Biturbo Imola Yellow (2001)
• Custom MTM 460hp manually tuned by Peter Link on MTM dyno at Ingolstadt HQ.
• Custom Full Milltek: Sport-Cats / Mid-Silencer: suppressed / End-Silencer: reduced.
• Full Mov'It upgrade: Front 380mm - 6 pistons / Rear 220mm - 4 pistons / Parking addon.
- Joined the Dark Side (aka. Darth Elon) circa 2013.
peterb
Re: BATTERY PROBS
Post by peterb » Wed Jan 21, 2004 3:20 pm
My old A4 did this just once. One morning, after about a week of not being used, the battery had absolutely no power. No electricals had been left turned on - just the alarm set. I recharged the battery and it didn't happen again in 3.5 years ownership.
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
johneroberts
Re: BATTERY PROBS
Post by johneroberts » Wed Jan 21, 2004 4:29 pm
Deffo an after market device fitted which has been removed and there are no visable signs of it, suggest you look at the feeds to and from the battery, ive had mine 2.75 years and never a moments problem, but there again i dont have any after market stuff fitted.
jr
Driving is believing
RS246 Founder
kcsun
Re: BATTERY PROBS
Post by kcsun » Wed Jan 21, 2004 8:15 pm
I have left mine in the garage, locked since Oulten park (November) till last week and it started perfectly. [img]images/graemlins/clap.gif[/img]
Only extra fitted is Trackstar
kc [img]images/graemlins/s4anogaro.gif[/img]
drjones
Re: BATTERY PROBS
Post by drjones » Wed Jan 21, 2004 8:55 pm
If you disconnect the - lead on the battery and put an Ohm meter between the lead and battery terminal you will show a reading which is the drain on your battery, if you then take a fuse out one by one you will isolate the cause and you can then investigate that circuit!
Good A! [img]images/graemlins/thumbs.gif[/img]
Darren.
RS4 (standard) SOLD and I miss it!
Ur Quattro (360bhp)
A3 1.6SE (for her indoors)
7 series (ugly but smooth)
427 Cobra
GT40
teknobod
Re: BATTERY PROBS
Post by teknobod » Wed Jan 21, 2004 11:30 pm
Just to clarify that comment, he means a voltmeter set to the amps range. Do not under any circumstances connect it reading ohms or you'll fry the meter. [img]images/graemlins/thumbs.gif[/img]
Although I do not think the base reading will necessarily be 0 amps. It would be useful to measure a "good" RS4 to give you a starting point.
Andy
drjones
Re: BATTERY PROBS
Post by drjones » Thu Jan 22, 2004 10:02 am
Thanks For that Andy, you are absolutely right long day and all that [img]images/graemlins/smile_smoking.gif[/img]
Darren.
Ur Quattro (360bhp)
427 Cobra
GT40
andnik
Re: BATTERY PROBS
Post by andnik » Thu Jan 22, 2004 10:19 am
OK everyone go and measure yours cars lust for power while parked and post your results lets see who has the most thirsty [img]images/graemlins/rs4-button.jpg[/img]
probably me!! [img]images/graemlins/29428-red4.gif[/img]
Dippy
Re: BATTERY PROBS
Post by Dippy » Thu Jan 22, 2004 1:26 pm
No he doesn't. Voltmeter only measure volts. He either means an ammeter or a multimeter set to amps. [img]images/graemlins/tongue.gif[/img]
2001 Silver S4 Avant
Steve_Mc
Re: BATTERY PROBS
Post by Steve_Mc » Thu Jan 22, 2004 5:02 pm
Both correct as current is a function of voltage [img]images/graemlins/tongue.gif[/img]
You never really learn to swear until you learn to drive.
RS4 - as standard as the day it was born
teknobod
Re: BATTERY PROBS
Post by teknobod » Thu Jan 22, 2004 5:13 pm
Touche!! [img]images/graemlins/spineyes.gif[/img]
There's always one!
You know what I mean.
Having thought about it further, it should also be pointed out that the reading should be taken with the ignition off as this is when the drain is taking place.
Andy
JAMES
Re: BATTERY PROBS
Post by JAMES » Thu Jan 22, 2004 5:17 pm
my car seems a bit slow turning over when i have had the stereo on and engine off.i think the battery has had it,has anybody bought one from audi,if so how much.should i go elsewhere although i would like to stick to audi parts.
previous: RS2, RS4 2.7, RS4 4.2.
Current: S8 PLUS
