Lost the kick at 5000 rpm
ArthurPE
Post by ArthurPE » Sun Jul 04, 2010 1:14 am
I don't believe this TSB sets the MIL, they usually say when it does and give the code
example:
3. ELECTRICAL SYSTEM:WIRING Bulletin Number: KM-1379
Bulletin Date: Jun 2009
Vehicle: 2,008 Audi RS 4
Summary:
AUDI: MIL LIGHT ON AND DTC P2294 (FUEL PRESSURE REGULATOR 2 CONTROL CIRCUIT), P2295 (FUEL PRESSURE REGULATOR 2 CONTROL CIRCUIT LOW), P2296 (FUEL PRESSURE REGULATOR 2 CONTROL CIRCUIT HIGH) IN FAULT MEMORY DRIVABILITY IS NOT AFFECTED. WIRING ( NHTSA ITEM NUMBER - 10030593 )
could be flaps, could be lack of vacuum not moving the flaps
do you have an after market exhaust?
Dave_M
Post by Dave_M » Sun Jul 04, 2010 10:57 am
Arthur
Car is totally standard.
2007 B7 RS4 Daytona Avant (the daily driver)
Other current toys: 210bhp Caterham 7 (track toy), 1994 380bhp Escort Cosworth Monte (awaiting engine rebuild), MX5 1.8 Sport (strictly my wife's!)
Gone: Nissan 350z roadster, 205 GTI Mi16, Classic Impreza 2000 Turbo, Nissan Sunny GTiR, Corrado G60, 205 GTI 1.9, Rover Metro Gta (don't ask!), Escort 1.6i cabbie, MG Metro (first car)
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Jul 04, 2010 1:33 pm
It is the inlet manifold with a one way valve that goes off to a reservoir that keeps the vacuum. If the one way valve or any hoses are split then you lose vacuum control for everything.
http://www.MRCtuning.com
lengster1
Post by lengster1 » Sun Jul 04, 2010 1:38 pm
If one way valve failed is it possible the car could suck air in and upset the mixture etc?
lengster1
Post by lengster1 » Sun Jul 04, 2010 1:39 pm
Would you loose exhaust valve function too?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Jul 04, 2010 2:32 pm
you would - on idle it might open as you are getting constant vacuum - but rev it and see if they stay open or starting flapping.
if you have a acuum issue you run 290PS and no timing and it runs really rich.
ArthurPE
Post by ArthurPE » Sun Jul 04, 2010 5:33 pm
lengster1 wrote:If one way valve failed is it possible the car could suck air in and upset the mixture etc?
these cars are unique
due to valve overlap the engine does not generate enough constant vacuum to power auxiliaries so it required an external vacuum source, and there are two, a primary and back-up...
primary: electric vacuum pump
back-up: a venturi pump over the throttle body, air flow induces a differential pressure, with one side being vacuum (low or negative) relative to atmosphere (hi or positive)...
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Jul 04, 2010 6:29 pm
where is the electric pump?
neckarsulm
Post by neckarsulm » Sun Jul 04, 2010 7:15 pm
Does the kick occur when not in Sport mode?
mark758
Post by mark758 » Sun Jul 04, 2010 11:20 pm
Doug_S2 wrote:where is the electric pump?
This fella knows, bottom of this page, but doesn't say !
http://bbs.22b.com/cgi-bin/ultimatebb.c ... 0;t=000938
2013 Ibis White RS7¬
¦ParkingPackPlus¦Sunroof¦HUD¦AudiConnect¦HeatedRearSeats¦RearSideAirbags¦RedBrakeCalipers¦QuattroPuddelights¦SoftCloseDoors¦NightVision¦Dynamic Package¦CarbonPackage¦CarbonMirrors¦21" GlossBlack¦ACC¦Stop&Go¦PreSensePlus¦SideAssist¦LaneAssist¦B&O¦BlackOptics¦OEMBlackBadging¦Gyeon Q2 Duraflex¦
ArthurPE
Post by ArthurPE » Sun Jul 04, 2010 11:56 pm
after re-reading it looks like the venturi (suction) is the primary and the electric the secondary...
the electric kicks on if not enough vacuum is created by the venturi, eg, when the throttle is full open (no diff press)
this low vacuum is sensed and the electric pump kicks on...all via the ECU...
I don't know where the pump is situated...I'll go snoop around
edit:
note US LHD car
it looks like it's below the plastic shield near the power steering resevoir, brake components, etc.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Mon Jul 05, 2010 9:42 am
It is not clear in the parts catalogue were that connects to the vaccum control lines for the intake flaps and exhaust flaps.
P_G
Post by P_G » Mon Jul 05, 2010 9:48 am
neckarsulm wrote:Does the kick occur when not in Sport mode?
Yes.
neckarsulm
Post by neckarsulm » Sat Jul 10, 2010 10:14 pm
In Sport mode the exhaust sounds a lot more reasonant at around 3000rpm, does that mean my vacuum is OK as exhaust valves aren't flapping?
The 2 DTCs I had when I scanned the car just before I bought it, one of which related to inlet manifold still haven't come back.
ArthurPE
Post by ArthurPE » Sat Jul 10, 2010 11:56 pm
the inlet manifold fault may or may not have a code...
do some 3k to 8k 3rd gear runs
start at 2000, slowly squeeze throttle until 100% at 2600 or so
start at it approaches 3000, stop at it passes 8000...you will hit the rev limiter right after
use the OBC timer
if your flaps are messed up (a vacuum leak) you will be waaaay down on power, as evidenced by numerous dyno plots where that was the problem...
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 75 guests
