led drl's
well done fella, you cant beat a bit of white...
bought my piaa bulbs from here they had the full range in stock
http://lkperformancestyling.co.uk/
B5 S4 KO'4 black saloon sunroof......
B5 RS4 Goodwood Green,sunroof, nav tv, short shifter,
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
Just made this change to both the side lights & the DRLs. Took about an hour from start to finish most of which was re-clipping the air-vent thing which seems to have been badly assembled when serviced. Turning the DRL fittings was awkward so some long-nose pliers would be a good idea but didn't bother with myself.
Bought the bulbs from www.piaaonline.co.uk in the end as the previous mentioned suppliers did not have stock & was only place that had both bulbs for sale - came next day, well packed but I think a little more expensive although ex-rate may be the cause...
I also put the H11 Philips CrystalVision 4300K into the Fogs. Much improved.
http://www.autolamps-online.com/halogen/cvcentre.htm
2013 Ibis White RS7¬
¦ParkingPackPlus¦Sunroof¦HUD¦AudiConnect¦HeatedRearSeats¦RearSideAirbags¦RedBrakeCalipers¦QuattroPuddelights¦SoftCloseDoors¦NightVision¦Dynamic Package¦CarbonPackage¦CarbonMirrors¦21" GlossBlack¦ACC¦Stop&Go¦PreSensePlus¦SideAssist¦LaneAssist¦B&O¦BlackOptics¦OEMBlackBadging¦Gyeon Q2 Duraflex¦
Just when I thought 60 UKP on bulbs was enough...mark758 wrote:I also put the H11 Philips CrystalVision 4300K into the Fogs. Much improved.
I know
I justified as it improves my ability to pick potholes out on b-roads I use and avoid even pricier wheel repair
Ha Ha - given I don't use fogs (scares me in the dark when turn the auto-lights off to find the on again) or coming home lights I might have to pass on these !
I did wonder why had spent so much on what are just little wedge bulbs until I saw the blue ones that were free with the H11s !
Can we put LEDs in the wedges (side/parking lights) or do these trigger a fault too ?
I believe PIAA do a LED bulb with added electronics to overcome this issue...trouble is this little box of tricks added on makes installation a bit too tight!
Marcus-RS4
Marcus-RS4
Just done some more digging and its true! http://www.piaa.co.uk/bulbs/bulbs.asp
- PetrolDave
ANY blue lights (or lights that look blue to the MOT tester) on a non-emergency service vehicle are not only an MOT failure but also illegal and are a reason for the Police to stop you.Marcus-RS4 wrote:Word of caution! My Car just failed the MOT with the PIAA's in - switch them out before you take them in for it..
Cant have a blue tinge apparently? I was shocked at first, but do remember a similar issue in the past...
I thought you had the white light LED and not the blue tint one, do you have a pic? was it Audi who did the MOT?Marcus-RS4 wrote:Word of caution! My Car just failed the MOT with the PIAA's in - switch them out before you take them in for it..
but when not on they look blue
Users browsing this forum: No registered users and 243 guests
