wheel spacers
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
chris22
wheel spacers
Post by chris22 » Tue Dec 30, 2003 8:58 pm
Has anyone fiited spacers to there S3?
Where do I get them from, what sizes and how much????
Is it worth doing the mod, Im running std brakes.
Bass [img]images/graemlins/s3addict.gif[/img]
Paul-RS
Re: wheel spacers
Post by Paul-RS » Tue Dec 30, 2003 9:20 pm
1.Yes
2.AmD or Forge is the usuall
3.I got 10mm front 15mm rear and new lockers. approx £160 (AmD)
some go for 10mm /10mm so the bolts are all same length
4.I needed them for the Porkers, and wanted to bring out the rear to match. A worth while cosmetic improvement, as it fully fills out the arches. Increases track width slightly too.
TarmacTerrorist
Re: wheel spacers
Post by TarmacTerrorist » Tue Dec 30, 2003 10:20 pm
Both of my front spacers have collapsed (locating stub sheared off) thought the wheels needed balancing until I found the spacers in two bits and wheels floating around on what was left of the spacer. Won't be bothering putting anymore on the car again [img]images/graemlins/033102bad_1_prv.gif[/img]
Too much is bad.
Plenty is better.
chris22
Re: wheel spacers
Post by chris22 » Tue Dec 30, 2003 10:38 pm
Mmmm intresting. I thought RS4 came standard with spacers, or is it the style of the alloys.
Cheers Paul Ive heard of fitting spacers to clear different porkers but ive also heard a lot of probs, don't think im gonna bother [img]images/graemlins/boots.gif[/img]
Paul-RS
Re: wheel spacers
Post by Paul-RS » Tue Dec 30, 2003 11:09 pm
first time ive heard of a problem. there are alot of us with porker brakes that have no choice but use them.
sitas3
Re: wheel spacers
Post by sitas3 » Tue Dec 30, 2003 11:29 pm
Paul, IIRC we only have to use the spacers with our brakes because of the design of the RSTT wheels. I'm sure that the 17" Avus is OK with this.
[img]images/graemlins/beerchug.gif[/img]
Paul-RS
Re: wheel spacers
Post by Paul-RS » Tue Dec 30, 2003 11:50 pm
correct. Avus 17" you dont need spacers.
RSTT 18" you do, because of the shape of the back of the spokes.
chris22
Re: wheel spacers
Post by chris22 » Tue Dec 30, 2003 11:55 pm
Ive heard of probs on the rs4's before and s4's but not s3's.
Im running 18" RST's.... sod it I'll go with your advice.
Does it handler any better?
Paul-RS
Re: wheel spacers
Post by Paul-RS » Wed Dec 31, 2003 12:05 am
Looks so much better [img]images/graemlins/laugh.gif[/img] especially the rear. Gives it a more aggressive stance.
personal choice on if you go 10mm/10mm or 10mm/15mm like me.
the latter does mean you have two lengths of bolts
Handling, well ive had 2 S3's now. both with/without spacers/Porkers and the latest one with Quattro GmBh lowered suspension, and it certaintly hasnt had a negative effect on handling. I think its made it more surefooted.
chris22
Re: wheel spacers
Post by chris22 » Wed Dec 31, 2003 12:18 am
That's good cos Im running 18" RST's and Gmbh lowered.
I was a bit concerned about the wheels catching the arches.
My previously S3 had 17" avis and std suspension and seemed to handle better! or is it just me [img]images/graemlins/confused.gif[/img]
Paul-RS
Re: wheel spacers
Post by Paul-RS » Wed Dec 31, 2003 12:31 am
you can scuff the front inner arch liner on particularly rough roads, when making good progress [img]images/graemlins/wink.gif[/img] [img]images/graemlins/sekret.gif[/img]
But mines been fine since i brought the tire pressures back up to 36psi instead of the 33psi they were on.
DuncS3
Re: wheel spacers
Post by DuncS3 » Wed Dec 31, 2003 9:16 am
I have run 10mm spacers for a long while now with no problems. Agree with Paul, the car looks so much better with spacers on and I would recommend them 100%. No negative effects on handling either (and no rubbing either on 36 psi) running 18" RSTTs with lowered suspension.
Dunc [img]images/graemlins/s3addict.gif[/img]
Domcj
Re: wheel spacers
Post by Domcj » Mon Jan 05, 2004 4:25 pm
Sorry to be a pain but I am a newbie to the S3 after driving VW's for years and here mentions of GmBH ?? What is this I know its for suspension but what ?
Dom Johnson
Club GTi Glos Region Host
domjohnson@blueyonder.co.uk
Paul-RS
Re: wheel spacers
Post by Paul-RS » Mon Jan 05, 2004 5:03 pm
GmbH is equvalent to our Limited, after a company name
Gesellschaft mit begrenzter Haftung - a limited company
Its simply refered as Quattro GmbH suspension (optional lowered 20mm, uprated and stiffened upgrade) to avoid confusion against the standard fitted suspension to quattros...
S3MUD
Re: wheel spacers
Post by S3MUD » Wed Jan 07, 2004 2:53 pm
So this is the standard suspension for s3's?
Got to be the youngest here?
Return to “S3 (Typ 8L) 1999-2003”
Users browsing this forum: Google [Bot] and 68 guests
