Changing one worn tyre
Mikeyboy
Post by Mikeyboy » Mon Jul 21, 2008 12:59 pm
I had a wheel allignment problem which has meant the nearside front looks like its done 4k more than every other tyre. Do I really need to change EVERY tyre because of it or can I just change the fronts etc?
Thanks Mikeyboy
lma07
RE: Changing one worn tyre
Post by lma07 » Mon Jul 21, 2008 1:12 pm
I recently changed the front 2 tyres - back still reading 5mm (didn't expect that) - I did keep to the same brand though.
P_G
Post by P_G » Mon Jul 21, 2008 1:19 pm
Maximum you would need to change is the one on the same axle, depends on what is left tread wise on the 'unworn' one. If only 2-3mm would change both.
Mikeyboy
Post by Mikeyboy » Mon Jul 21, 2008 1:43 pm
Phew, well thats going to save me a bit. Unless I decide to change to a whole different make I guess but thas a different story.
sonny
Post by sonny » Tue Jul 22, 2008 7:42 am
I have a slow puncture on my front left, do you think i will have to swap both tyres out, they are in A1 condition already?
P_G
Post by P_G » Tue Jul 22, 2008 9:00 am
Where on the tyre is the pncture point? If fairyl central surely you could just have it repaired?
sonny
Post by sonny » Tue Jul 22, 2008 7:23 pm
Not sure mate, every 2-3 days my pressure light comes on, so i just pump it up and away I go, but i dont want a blow out due to a small hole!....and i don even know it its a hole yet mate (im not in the UK at the mo to check), one other thing, is it illeagle to plug a tyre in the UK?
scoobyc
Post by scoobyc » Tue Jul 22, 2008 7:29 pm
i'm sure its ok if its in the centre 3/4's of the tread pattern and your only allowed 2 plugs in a z-rated tyre i think, looked in to it ages ago and can roughly remember that but might be slightly out! If its anywhere near the sidewall its a definite no.
wait for it......
RS4 Avant - Daytona Grey SOLD
Focus ST wth a tweak ;)
03 911 (996) turbo SOLD
06 Wrx impreza SOLD
lma07
Post by lma07 » Tue Jul 22, 2008 7:31 pm
I have had 2 slow punctures on my car to date. And did the same pump up and ignore it for a while.
I normally check where the nail is before going to a tyre place. On both occasions they have been plugged. First place marked my alloys. Grrr. The place was near my work and is used to dealing with trucks.
Second time i took it to audi who plugged it and did no damage. If audi did it then i take it to be legal.
tweek
Post by tweek » Tue Jul 22, 2008 8:08 pm
Always stick the tyre on the rear of the car if possible. If it has a problem it is easier to control than if its on the front...
shunt1tech
Post by shunt1tech » Tue Jul 22, 2008 9:21 pm
Modern plugs and glues for repairing punctures are much better than years ago , also there is the slime that bikers use is there tyres which also helps with temperature control .
SR71
Post by SR71 » Tue Jul 22, 2008 9:47 pm
I might be stating the obvious, but make sure it isn't just a dodgy valve...
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
mbelle
Post by mbelle » Wed Jul 23, 2008 2:32 pm
Similar to what P_G states, I was advised by Audi that, whenever needing to change just 1 tyre, providing there is 5mm (or more) on the other axle's tyre then you should be OK.
Anything less, change them both.
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Marcus-RS4
Post by Marcus-RS4 » Wed Jul 23, 2008 4:45 pm
Gone are the days (thanks god) of my Calibra Turbo 4x4 system, where you had to have a <3mm variance between all tyres, or the transfer box would explode! :shock:
chrissyr32
Post by chrissyr32 » Wed Jul 23, 2008 5:15 pm
SJ-RS4 wrote:Not sure mate, every 2-3 days my pressure light comes on, so i just pump it up and away I go, but i dont want a blow out due to a small hole!....and i don even know it its a hole yet mate (im not in the UK at the mo to check), one other thing, is it illeagle to plug a tyre in the UK?
Bad move mate.If you keep running on the tyre when it requires air,you will knack the inner sidewall (inside of tyre).When you eventully get it repaired rubber "dust and small shards" will be in the tyre.This will have come from running on the incorrectly inflated tyre causing wear on the inside.
Happened tto me,tyre fitter said he could repair the puncture no prob,but when he took the trye off it was fooked!!!
Theres another 230 plus. :shock:
GET IT FIXED, but it may be too late.
Users browsing this forum: Google Adsense [Bot] and 163 guests
