Show us your boost gauges !!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
tdiquattro
Post by tdiquattro » Fri May 02, 2008 2:03 pm
Stigter wrote:Its that how you have the gauge lights powered tdiquattro? Is it really that simple as tapping onto the feed there?
yep, just tap into the positive feed to the light behind the vent wheel (on a facelift) works a treat, my omori matches the dash brightness exactly, and adjusts with the dash.
The best way in is through the ecu waterproof housing, there is a rubber unused way in below the main ecu to engine cable entry, cut and then re-seal with silicone.
Nige'
2000 silver S4 Saloon
Stigter
Post by Stigter » Fri May 02, 2008 2:14 pm
Adam any sign of it from the states as yet?
s4-99
Post by s4-99 » Mon May 19, 2008 9:35 pm
Recieved my AWE boost gauge today. I'm going to fit it later this week :D . Anyone that has already fitted one or similar, do you follow the AWE instructions like for like, or have you done anything different thats easier?
thanks
Hmmm, its fast but is it fast enough!!!
AdamS4
Post by AdamS4 » Tue May 20, 2008 7:12 am
Yeah, recieved it about 3/4 days after ordering it.
All fitted, will post some piccys tomo
dr_wimpkins
Post by dr_wimpkins » Tue May 20, 2008 12:41 pm
power the light from the feed to the vent roller back light to get it to be dimmed like stock.
Ive powered mine that way, but its not the same brightness, though it does dim with the controls.
All BLOW and no GO.........
Blue_Thunder
Post by Blue_Thunder » Tue May 20, 2008 2:21 pm
I followed the AWE instructions without issue.
One thing which I did change was to add some extra wiring onto what was provided so that I could route the power cables alongside the existing looms, ie: along the top of the carpet under the dash.
Without adding extra wiring, you just had to have the power cables hanging across the front of the pedals (although they would be tucked up inside the lower dash panel when replaced).
I never managed to do anything with the illumination on mine (electrical), although I believe the mechanical gauge from AWE isn't as bright.
s4-99
Post by s4-99 » Tue May 20, 2008 7:20 pm
Cheers guys, so it sounds easier to connect it to the vent light, where do you connect the black wire if you do it this way, as it is only the white wire that makes it light up, is that right? Another thing i have noticed is the needle doesn't sit exact on the zero, it is just on top of the line below, is this normal?
s4-99
Post by s4-99 » Tue May 20, 2008 9:24 pm
This is what i received when i got my gauge yesterday, is there anything else i need to get before fitting? I know i need a 12mm grommet, i hope thats it though. I've put a pic of where the needle is at aswell.
Cheers.
AdamS4
Post by AdamS4 » Thu May 29, 2008 12:06 pm
dace
Post by dace » Thu May 29, 2008 2:16 pm
s4-99 wrote:This is what i received when i got my gauge yesterday, is there anything else i need to get before fitting? I know i need a 12mm grommet, i hope thats it though. I've put a pic of where the needle is at aswell.
Cheers.
I have the same gauge and my needle is in the very same position.
s4-99
Post by s4-99 » Thu May 29, 2008 10:26 pm
Cheers Dave :thumbs:
andream88
Post by andream88 » Thu May 29, 2008 11:06 pm
AWE is offering a new gauge, without the problem at the needle...for 75$.
Bye
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
andream88
Post by andream88 » Thu May 29, 2008 11:07 pm
Have a look at this kit:
http://podi.ca/Packages.aspx?CarID=5
THE FIRST ;)
There is a 50$ discount for the Audiziners !!!
Andrea
Rs4 b5 06/2001
bobbler
Post by bobbler » Sat May 31, 2008 10:54 am
andream88 wrote:Have a look at this kit:
THE FIRST ;)
Andrea
Oh dear. That is pretty horrific TBH.
Why not just go the whole rice tuner special and stick a plastic pod down the side of the window or a bit of double sided tape to the top of the dash. Cheaper and looks just as crap.
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
stapo69
Post by stapo69 » Mon Jun 02, 2008 6:41 pm
Made this, just to be a bit different. Swoosh 60mm boost gauge. Waiting for some black headlining to cover it, make it a bit more OEM.
Users browsing this forum: No registered users and 72 guests
