Knocking noise from the rear drivers side?!?!?!?!
bigfra
Post by bigfra » Thu May 08, 2008 9:27 am
As title,getting a knocking noise from the rear of the car and i think it's coming from the driver's side!It only happens after ive been driving for a while and it's starting to REALLY do my tit's in!!
Any idea's lad's?
Fraser :(
MTM Stage 2,Billi PSS9's,Milltek,MTM Bimota's
GardinerG
RE: Knocking noise from the rear drivers side?!?!?!?!
Post by GardinerG » Thu May 08, 2008 9:33 am
Does it sound like it's coming from the inside or outside? It's not the exhaust knocking against something is it (it expands when hot)?
bigfra
Post by bigfra » Thu May 08, 2008 9:38 am
Hmmm,good question.Im sure it's coming from the inside but when i stop the car and bounce the back up and down i can't here ANYTHING!It's a Milltek exhaust that's on it so would that make a difference??
grizz
Post by grizz » Thu May 08, 2008 2:49 pm
When the milltek gets hot it expands, it can knock if not fitted wright.
Unit 20
0151 3366888
HyOctane
Post by HyOctane » Thu May 08, 2008 4:37 pm
You should not be able to bounce the car up and down. Sounds like the dreaded DRC failure has been wretched upon you.
bigfra
Post by bigfra » Thu May 08, 2008 4:50 pm
HyOctane wrote:You should not be able to bounce the car up and down. Sounds like the dreaded DRC failure has been wretched upon you.
I have Billstein coil overs on and i don't mean BOUNCE as in bounce,i just mean it doesnt knock when i move it up and down at the back!
skiwi
Post by skiwi » Thu May 08, 2008 7:45 pm
i take it is not a rythmic knocking, rather than intermittent?
suggest exhaust (check by wiggling the tailpipe when hot) or cat.
grizz
Post by grizz » Thu May 08, 2008 8:18 pm
It could be a anti roll bar link .
Unit 20
0151 3366888
mattysupra
Post by mattysupra » Thu May 08, 2008 8:44 pm
as grizz has just said! That would be my guess!
SteveH
Post by SteveH » Thu May 08, 2008 9:28 pm
I had an anti-roll bar bolt fail ages ago, that knocked... simple bolt and all was good.
Present:...
Past:
bigfra
Post by bigfra » Fri May 09, 2008 8:13 am
Thanks lad's.ill give all of the above a try!!
Fraser :D
R1NGA
Post by R1NGA » Fri May 09, 2008 10:54 am
Almost certain to be the exhaust hitting the rear subframe, where the pipe does its dogleg. Mine does exactly the same and I will eventually get round to having it bent a little further to correct it. Think I have a slightly inaccurate midsection pipe.
Phil G
Users browsing this forum: Bing [Bot] and 135 guests
