S4 - Oil Worries
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
stark
S4 - Oil Worries
Post by stark » Thu May 01, 2008 9:47 am
Red oil management light came on in DIS yesterday morn with 3 beeps, checked oil level - was hovvering around min.. this was topped up later in the day with the same long life oil used by Audi. However the same thing happened when i started the car this morning - oil light with 3 beeps... checked level again, was half way between min and max. Is this sufficient or should i top it up to the max mark and hope the display does not beep at me again...?
Even yesterday however, i only had the light come on once in the morning, even though i had to stop and restart a couple of times during the day. Could it be a sensor issue?
Any advice would be great....
JonnyX
RE: S4 - Oil Worries
Post by JonnyX » Thu May 01, 2008 11:24 am
Could be sensor. Is the low oil level light or the pressure light? (can't remember if they are different...)
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
stark
Post by stark » Thu May 01, 2008 11:39 am
Not sure, ive read somewhere that there are two lights for oil, an amber and a red, amber usually signifies low oil, red is oil pressure.. could someone confirm this? so it was the red light that came up, but the oil was low...
Dippy
Post by Dippy » Thu May 01, 2008 12:32 pm
Yes I think you are right - and also a low priority warning only has one beep. You must have low oil pressure (real or sensor fault).
2001 Silver S4 Avant
MCB
Post by MCB » Thu May 01, 2008 5:21 pm
Now you have filled the oil to the correct level are you still having a fault display?
S4B5 Avant
imolas4uk
Post by imolas4uk » Thu May 01, 2008 10:24 pm
red light is low oil pressure.
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
Philws4
Post by Philws4 » Fri May 02, 2008 8:52 pm
Last year i had an oil pressure switch fail on me so do
make sure you check this out first before getting too worried :o
Tis a PITA of a job to change though!!
B5 S4
stark
Post by stark » Tue May 06, 2008 10:32 pm
Thanks for the replies guys, topped up the oil a little more, no issues on that front any longer... however, noticed that my coolant level was extremely low, way below min level - kinda strange it hadnt warned me abt it... topped this up, monitoring it now, car has been driving slightly sluggish - not feeling as poweful as it should. Think a trip down to MRC would probably be good... I aint too clued up on these cars yet, but thinking maybe some fault codes might have developed? Note, coolant level has not dropped since thursday when i topped it up, must be a very small leak someplace... Any ideas?
Blue_Thunder
Post by Blue_Thunder » Wed May 07, 2008 9:14 am
What are the chances... driving to work today, I got exactly the same warning sign :(
Over to Unit 20 me thinks...
Blue_Thunder
Post by Blue_Thunder » Wed May 07, 2008 10:51 am
Philws4 wrote:Last year i had an oil pressure switch fail on me so do
Just found your write-up here Phil:
http://www.rs246.com/index.php?name=PNp ... p&start=15
Users browsing this forum: No registered users and 112 guests
