MAF sensor
s4woody
MAF sensor
Post by s4woody » Tue Apr 15, 2008 12:01 am
here's a thought..in my car i have 2 maf sensors..on them maf sensors i have to small diodes..now these diodes apparently are the diodes that measure the temp in the maf/engine area and adjust the power accordingly..
there is a kit i can buy that simply disconnects the temp sensor from the mafs to give a more accurate reading thus stopping the ECU from backing off the power once the engine is at operating temp or a hot day...
cant remember if the Audi maf have them..
here's a pic of my maf sensors..
i'm wondering if the same sensor can be used on an S/RS to stop the ECU from backing off the power at higher temps...
GARTH ROAD MOT CENTRE LTD
020 83353032
dummi
RE: MAF sensor
Post by dummi » Tue Apr 15, 2008 9:05 am
its not really more accurate is it, its like that resistor mod of ebay fooling the air sensor. not sure if the audi ones come with a temp sensor, I heard in the early hotwire days there were trucks with them not passenger cars. if I were you I would take full advantage of that air sensor in mapping
Nige_RS4
RE: MAF sensor
Post by Nige_RS4 » Tue Apr 15, 2008 9:23 am
Woody, I can recall seeing that diode on an RS4 MAF sensor.
Do you have a link to that kit?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
s4woody
RE: MAF sensor
Post by s4woody » Tue Apr 15, 2008 9:36 am
http://www.beastpower.com/Merchant2/mer ... e_Code=BMI
although its a BM site it mite explain things a little better..i will do a search on the subject and see what else i can find...
020 83353032
S4TAN
RE: MAF sensor
Post by S4TAN » Tue Apr 15, 2008 12:01 pm
The S4 MAF sensor does NOT have the diodes.
Deus ex machina
Ads4
RE: MAF sensor
Post by Ads4 » Tue Apr 15, 2008 12:59 pm
Julian would know...he cleans his weekly :D
Adam.
MRC B5 S4 Avant.
S4TAN
RE: MAF sensor
Post by S4TAN » Tue Apr 15, 2008 1:02 pm
... and my MAF sensor too! :D
Deus ex machina
S2tuner
Trader (Expired)
RE: MAF sensor
Post by S2tuner » Tue Apr 15, 2008 1:33 pm
Nice ebay resistor trick tuning there, love it, I think I'll try that instead of remapping :lol:
am8631
RE: MAF sensor
Post by am8631 » Tue Apr 15, 2008 4:09 pm
Having read the site all it does it moves the temp sensing part of the MAF to the front air dam. The reason for this is that they say there is heat soak in the MAF area and this is giving the ecu an incorrect reading by as much as 45F ! Backwards thinking if you ask me - the air temp at the sensor will surely be the temp of the air entering the engine so thats what the ecu needs to know, whats the point of telling the ecu the outside air temp?
s4woody
RE: MAF sensor
Post by s4woody » Tue Apr 15, 2008 4:50 pm
mihnea your an :assflash: ..VW and Audi maf's both fit most BMW's including mine..if the resistor is replaced from a fooked Bm maf onto a new VW/Audi maf the EML light stays out..nothing to do with trickery...
are you really sure thats the right sort of question to be asking..doesn't all if not most S/RS cars suffer from heat soak..does that not back off the power..how can moving a sensor that measures either air or engine bay temps be a bad thing..
what happens when you sit in traffic on a hot day..you power is down until you start moving again..the same as on a rolling rd..the fans aint capable of keeping the AIT's down so the power is backed off..backward question if you ask me...
try looking further than this being about my M5..
020 83353032
MarkB
Re: RE: MAF sensor
Post by MarkB » Tue Apr 15, 2008 5:08 pm
:lol:
Mark
S2tuner
Trader (Expired)
RE: Re: RE: MAF sensor
Post by S2tuner » Tue Apr 15, 2008 7:01 pm
At least thank god for Audis where the intake temp sensor is in the inlet manifold, and not in the MAF :lol:
s4woody
Post by s4woody » Tue Apr 15, 2008 7:05 pm
to true..and thank fook it can be moved as easy as falling off a log..
020 83353032
dummi
Re: RE: MAF sensor
Post by dummi » Tue Apr 15, 2008 9:19 pm
not trying to be antagonistic here its great your trying to mod the M5 like your old s4, actually I recall you cut a hole in the bonnet, I think that would actually be the thing to do here actually make the air temp into the MAF cooler rather than telling it the temp is like the outside temp, a remap would take this into account and use it to make more power when you are running cool, and when you are genuinely running hot it will <beep> it. anyway when was the last time you needed 505bhp in a traffic jam?
Blue_Thunder
Post by Blue_Thunder » Tue Apr 15, 2008 10:51 pm
I guess in a NA car, it doesn't really matter where the IAT sensors are as the air isn't passing through a turbo heated to hundreds of degrees.
I imagine that the IAT's into an NA inlet manifold would pretty much be the same as the ambient temp.
Return to “General Car Chat”
Users browsing this forum: No registered users and 145 guests
