Hi Guys,
Looking for a "pretty" set of rear brake discs for my car. Is anyone aware of rear discs that are drilled for the S4 B6/7?
After Market Rear Brake Discs - Drilled?
Hang on a minute though, for the B7 S4 you could actually get the B7 RS4 Brembo kit to fit because the fitmets were almost the same. It needed bolt hole fillers to make up the B6 drilled attachement holes and those in the B7 RS4 Brembo kit.
I remember because I have a B6 and did the B7 RS4 front brake kit but when it came to the rear I would have to have had a custom suspension job fitted to get the B7 RS4 disks, calipers and pads on.
So if you have a B7 result, if a B6 I had to stick with just the front end kit.
