RS246 Rolling Road Meet Sat 17th Nov Thorney Motorsport
Ads4
Post by Ads4 » Sun Nov 18, 2007 10:16 pm
Car spec (performance mods): B5 S4 Avant, K04s, MRC FMIC & re-map, 660cc injectors & Bosch Motorsport fuel pump. Milltek downpipes with 100 cel cats & Milltek Dual cat-back.
Dyno results: 452.8 bhp, 480ft/lbs
Best FATs run: 3.66
Adam.
MRC B5 S4 Avant.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Nov 18, 2007 10:16 pm
Spec: B5 S4, RS4 airbox, RS4 y pipe, Thick headgaskets, MRC intake pipes, Tubular Manifolds, MRC Hybrid Turbos, Phenolics, FMIC, 600cc injectors, 3" downpipes, dual 2.75" exhaust no cats one box, 23 psi flat (will make more low down boost/torque but limited to keep S4 rods in block)
dyno: 503.8bhp 525 ft-lb
fats: 2.8 on a dodgy rs4 box
MAF peak: 450
http://www.MRCtuning.com
rolskii
Post by rolskii » Sun Nov 18, 2007 10:18 pm
mine : B5 S4 - rs4 injectors, f/pump, i/c's, k04's, fat head gaskets, opened up airbox, AWE flat panel filter, rs4 pre-gutted d/pipes, customed 3"milltek & MRC map .... dont forget the miller light experience of the de-meshed MAF.....
Dyno results: 390.1 bhp, 420ft/lbs
Best Fats run:(3.9)
happy dayz .... party ....
spen
Post by spen » Sun Nov 18, 2007 10:33 pm
My Car :
2000 S4, K04s, tubular manifolds, 100 CPI cats, custom exhaust, FMIC, 720cc injectors (600 cc injectors at 4 bar differential?), RS4 MAF, 044 fuel pump, K&N cone filter. Bits of the intake are lagged. N249 delete. Horns relocated to make way for big oil cooler :)
499 bhp @6000 rpm, 515 ftlbs at 3600rpm
Best FATS (not on the day I had to be elsewhere) = 3.02 seconds.
Doug, 'keep s4 rods in the block' - you're starting to worry me!. I was going to aim for a few more ftlbs.
Jarv
Post by Jarv » Sun Nov 18, 2007 10:34 pm
Car: RS4 B5
Mods: Gutted pre-cats, Milltek resonated cat-back, 710n's and MRC custom remap.
Crank BHP: 425
Wheel BHP: 330.5
Torque @ crank: 542 Ft Lb's
MAF peak: 364.08 (unlike some, I don't have the ability to read the real peak MAF!)
FATS: 3.46
Mike
Q7
DavidT
Post by DavidT » Sun Nov 18, 2007 10:36 pm
Doug, you can update you're profile now: Audi S4 5?? bhp
Good idea on specs Clive, keep em coming, they make very interesting reading :shock:
neily
Post by neily » Sun Nov 18, 2007 10:39 pm
Car: RS4 B5
Mods: Milltek 200CPI cats, Milltek resonated cat-back, 710n's and MRC custom remap.
Crank BHP: 445
Wheel BHP: 334
Torque @ crank: 560 Ft Lb's @3300rpm
MAF peak: 364.08 (unlike some, I ALSO don't have the ability to read the real peak MAF!)
FATS: 3.41
2001 RS4 Avant - thats been touched by the MRC magic wand.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Nov 18, 2007 10:44 pm
Spencer - no more torque for you! I think we are on the limit on s4 bottom ends - just for longevity and that one time you get a batch of crap fuel it is better to say on the safe side of the max you can get from the bottom end! I think you will struggle to get much more out of the car as the turbos are pretty well maxed out. Rods, lower compression and bigger turbos is your next stage - and brakes!
I think the power and torque figures we are all getting is pretty amazing for not changing engine internals - not many manufacturers engineer their cars to take this much abuse.
S4TAN
Post by S4TAN » Sun Nov 18, 2007 10:49 pm
Car: B5 S4, K04's, 600cc injectors, RS4 i/c's, Milltek de-cat d/p's + dual cat back, walbro fuel pump, MRC map.
405.9bhp, 510ft-lb
best FATS: 3.70 (Clive's just sent me my logs and there's a 3.70 in there - a whole 0.08 seconds better than I originally thought :roll: )
Deus ex machina
DavidT
Post by DavidT » Sun Nov 18, 2007 10:49 pm
Who is collating the data for the FATS runs from the day please? I can't remember.
We should have best & best on day against the data I suppose. My average at this spec is 3.65, but the one from the day is 4.03.
rolskii
Post by rolskii » Sun Nov 18, 2007 10:50 pm
@ Spen .....impressed dude ..... need some of those manifolds ..... grrrr .... :shock:
whisky180
Post by whisky180 » Sun Nov 18, 2007 10:51 pm
great day, nice to meet everyone, although my nuts are still thawing out. big disapointment with the power figures (515 bhp & 450 torque) but fortunatley Doug and Minhea are taking the car in tomorrow to sort it. will be putting the car back on the rr so will post revised figures asap. big thanks to everyone who made the day possible
noggy blue s4, mildly modded
spen
Post by spen » Sun Nov 18, 2007 10:56 pm
D'oh. I'll take that as a warning then! Yellow card, no more 28psi mid range :(
Brakes. Check! Number two on the list. Number one is the oil leak. And a new windscreen wiper motor at 1.5.
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
DavidT
Post by DavidT » Sun Nov 18, 2007 10:57 pm
Yeah and your sig still says mildly modded. You need a B5 to get away with that :)
CliveH
Post by CliveH » Sun Nov 18, 2007 10:59 pm
DavidT wrote:Who is collating the data for the FATS runs from the day please? I can't remember.
Well I volunteered, and we have all the data on my laptop from the runs that David (Harper) did, but I think there are some more to collate?
Clive
Users browsing this forum: Majestic-12 [Bot] and 86 guests
