panel filter Vs cone filter
I is currently running 509bhp with a K&N panel filter but wanted a bit of Xtra noise and maybe 1bhp too.
I have always had very good gains with cone filters / induction kits in the past on previous cars, but how about on the RS4's?
Anyone running a cone filter atm?
I was going to go for a BMC Carbon Dynamic Airbox, and I sell loads to std motors with no problem, but the rumour is they restrict power at around 480bhp.
I was gonna get the K&N one and get a power run done if there is no definative answer anyway.
MTM air freshner,
98ron V Power,
Child seat
509 bhp
keep stock in place..the other's will help you lose power..you will not find many if any on here with a cone filter running big power..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
- 5th Gear
how does a cone filter destroy the maf ?
665 bhp + 586 lbft...
Most cone filters are oiled , the oil sticks to the maf and gives a poor reading.jimbo1234567 wrote:how does a cone filter destroy the maf ?![]()
Unit 20
0151 3366888
0151 3366888
do you want extra hot air?As Kieran says - riddle your airbox with holes! You'll get some extra noise then .... and some extra air.
Not all cone filters are oiled.
Pipercross ones come with out being oiled
Powertec ones use stainless steel gauze with no oil.
K&N panel filters are pre-oiled so surely the oil is not an issue.
I was chatting to a guy who fitted a Piercross cone to his S4, and the MAF <beep> itself. He replaced it with a brand new one, and since then the car has been fine. This is also true for a customer of mine with a TT.
I think the initial increase of airflow could be the reason the sensor goes wrong, as it is almost like it has been stuck there, reading the same <beep> forever, and fears change!!
I just want a bit of extra noise. My car sounds like a 500bhp Dyson !!! I may have to replace the centre section of the Milltek with a custom made straight through section, with no box instead.
MTM air freshner,
98ron V Power,
Child seat
509 bhp
I'm a bit like you - I like the noise of the induction kit... I've had a K&N one fitted to my RS for a few thousand miles, through France in 35 degree Centigrade heat and everything was fine. The MAF was fine, temperature was fine, and so on. I did however shield it well with proper 2-4 layer aluminium heat shield and ensured there was extra airflow to it from all sides.
I've since removed it and now have a K&N filter panel in the stock filter box - can't tell any difference on power without a rolling road, but it still works fine. No changes in temps or anything and no MAF issues.
I'm now toying with the idea of putting the K&N cone back in (as I love the sound) but making a proper circular aluminium heat shield and basically enclosing the cone in a heat shield box, with extra airflow from both the stock front vent and from my now removed headlight washers as a vent (see the front of the dahlback RS4 - yes i know it also has a vented carbon bonnet for additional air flow and cooling)
The only issue i have with the stock air box is the following. When the ECU decides it needs more air, it opens the flap in the front of the air box to let in more air - but surely as this is located just behind the headlight and above the turbo intercooler and near the exhaust manifold, it's going to suck in more hot air, than say an induction kit with some proper heat shielding and designated air flow...
As far as I can tell the more cold air the better, and whether that comes from the stock air box or a cone, or a filter panel it doesn't matter so long as it's cold. And obviously common sense tells you that oil on the MAF is bad... so the less oil the better on any filters. (please feel free to shout me down if you lot disagree)
I'm thinking i want to try all 3 options (stock, stock with filter panel and Cone with heat shield) and actually measure what's best. If there is only a couple of hp in it, then why not go with what you want, or what sounds best!
Just my 2p worth!
Stu.
Just my 2p worth!
Stu.
have a search for the darintake mod, its basically chopping a bit out the airbox.
this is used with a OEM filter on this baby
http://www.nogaroblue.com/8607/8974.html
Satan... your Evil
LOL
Satan... your Evil
S4 Crazy Horse. Ringsticker & MRC black magic.
