RS4 B5, big brakes=what is the best?????
quattrosteph
Post by quattrosteph » Fri Aug 11, 2006 9:37 pm
Hello guys,
I am thinking about an upgrade for the brakes on the front. What would be the best? I don't do trackdays but i want something really more powerfull than the OEM( rubbish!!) , I have been recommended the ones on the RS6+, i heard some good about them but there is so many more.....So guys what do you recommend?
Many thanks :greyrs4:
Porsche 996 Turbo S Atlas Grey.
RS4 B7 Avant Sprint Blue. Sold.
RS4 B5 Avus Silver with MRC magic . Sold (Best car ever )
S4 B6 Avant Nogaro blue. Sold
A6 Avant Silver . 2.5 TDI .Sold
Brooner
RE: RS4 B5, big brakes=what is the best?????
Post by Brooner » Fri Aug 11, 2006 9:47 pm
I've got the RS6 calipers with B7 RS4 disks straight bolt on an gut renchingly efective :FIREdevil: see link to my orignal post http://www.rs246.com/index.php?name=PNp ... ic&t=53686
Nige_RS4
Post by Nige_RS4 » Fri Aug 11, 2006 10:07 pm
Steph, RS6 calipers & pads fit straight onto the std RS4 (B5) disks - this should be more than satisfactory for road use.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
quattrosteph
Re: RE: RS4 B5, big brakes=what is the best?????
Post by quattrosteph » Fri Aug 11, 2006 10:34 pm
[quote="Nige_RS4"]Steph, RS6 calipers & pads fit straight onto the std RS4 (B5) disks - this should be more than satisfactory for road use.[
/quote]
Keeping my original discs and fit RS6 Calipers that is a good idea, should make a difference for sure without spending too much....
Is there any difference between RS6 calipers and RS6 Plus??
CliveH
Post by CliveH » Fri Aug 11, 2006 11:20 pm
quattrosteph wrote: Is there any difference between RS6 calipers and RS6 Plus??
Steph,
The RS6/RS6+ calipers are the same Brembo 8 pots - it's the discs which are different on the RS6+ (cross-drilled).
Clive
quattrosteph
Brakes
Post by quattrosteph » Sat Aug 12, 2006 6:16 pm
Are RS6 discs are bigger than RS4 B5 on diameter or the same??
OEM rs4 B5 can resiste with more powerfull calipers like the RS6? :?
Nige_RS4
RE: Brakes
Post by Nige_RS4 » Sat Aug 12, 2006 7:29 pm
Steph, they are slighty bigger (5mm), but if you fit them, you need to get a new mounting bracket for the caliper. Try the RS6 calipers & pads with std RS4 brakes first.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
quattrosteph
brakes
Post by quattrosteph » Sun Aug 13, 2006 6:30 pm
What would be the cost for the calipers +hoses+ bracket RS6? Vat included.
Do you know anyone who did that modif so i can contact him ? 8)
Nige_RS4
RE: brakes
Post by Nige_RS4 » Sun Aug 13, 2006 7:44 pm
Steph, like I said, try just fitting the calipers and pads as a first step (you may need hoses, as I've heard conflicting reports). They should be good enough for road use. If you need more, you can always upgrade to RS6+ discs at a later date (you will need the caliper bracket then). Give MRC a shout, they have done plenty of cars in the past.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Brooner
RE: brakes
Post by Brooner » Sun Aug 13, 2006 9:39 pm
If it's just the caliper change any garage that you regularly use that you can trust or if your a bit more handy straight bolt on and bleed brakes sipmle job if you have the equipment
Prices on my link
B7 RS4 disks 8E0 615 301AB £557.50 the pair
RS6 front brake hose 4B3 611 707A £63.96 the pair
RS6 brake pads 4B3 698 151A £169.03 the set
RS4 B7 rear disk left 8E0 615 601AB rear right 8E0 615 602D £187.75 each
Rear B7 RS4 pads 8E0 698 451H £109.35 the set
B7 RS4 rear brake hose 8E0 611 775M £95.00 the pair
B7 RS4 rear calipers rear left 8E0 615 423E rear right 8E0 615 424E B7 £86.51 each
Rs4 rear caliper brackets 8E0 615 425D £262.00 the pair
All the above from www.vagparts.com
RS6 calipers I got from Clive Harper but I would say about £700
quattrosteph
Brakes,
Post by quattrosteph » Mon Aug 14, 2006 9:26 pm
Well !! I went today to MRC for a suspension upgrade and i saw a complete set RS6 calipers+RS6 plus Discs.....well i couldn't resist!!! While the wheels are off Doug may you fit this as well!!!!
Really good job he did as always :wink: The difference is massive already even if the pads need to bed in. It's gonna be even better in few miles :D
I am not a silly billy on the road , i don't even do trackdays.! but i have to admit sometimes at high speed my RS4 B5 brakes did let me down few times especially under the rain.......So safety first :thumbs:
So it is worth it!! Thanks MRC for your good job :lol:
KayGee
RE: Brakes,
Post by KayGee » Tue Aug 15, 2006 3:53 pm
Try dswagen on Ebay, RS4 B7 £460 a pair. RS6 disks £390 a pair.
JustinM
RE: Brakes,
Post by JustinM » Sun Aug 27, 2006 5:20 pm
Can't really do better than APRacing.
quattrosteph
RS6 brakes
Post by quattrosteph » Mon Aug 28, 2006 9:15 pm
Really good and they look good to!! :thumbs:
Picture 206.jpg (141.19 KiB) Viewed 1124 times
SteveH
RE: RS6 brakes
Post by SteveH » Mon Aug 28, 2006 10:17 pm
Looking good Steph. Dont expect those alloys to stay so clean with the RS6 callipers... lots and lots of brake dust created by those big boys :wink:
Present:...
Past:
