Doors autolock-should they after stopping then moving again?
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
DavidT
Post by DavidT » Tue May 02, 2006 10:35 am
clive.harper wrote:
DavidT wrote:
clive.harper wrote:There must be a coding fix then...anyone...?
Sounds like a question for the Yahoo vag-com list. Are ya volunteering Clive ? ;)
Yes, I'll give it a go - if you give me a clue as to what the Yahoo vagcom list is...
Here it is: http://www.ross-tech.com/vag-com/discussion.html
peterb
Post by peterb » Tue May 02, 2006 1:47 pm
I don't believe that there is any parameter which controls this behaviour - I suspect that it's down to the firmware version in your central locking controller. I had mine upgraded from version D37 to D38 in order to fix a known bug. I can't be certain what the behaviour was before this update.
My little 'experiment' reminded me of one of the other 'clever' features - if you have the two stage unlocking enabled, the automatic unlock on removing the key only unlocks the door which was last unlocked so, after my experiment, my wife's door didn't unlock. The other thing which catches me out almost ever time I go to fill up is that the filler flap doesn't unlock with the driver's door - you need to unlock all the doors.
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
SimonS4MTM
Post by SimonS4MTM » Tue May 02, 2006 3:09 pm
My filler unlocks when only drivers door is unlocked!
david7m
Post by david7m » Tue May 02, 2006 3:15 pm
peterb wrote:I don't believe that there is any parameter which controls this behaviour - I suspect that it's down to the firmware version in your central locking controller. I had mine upgraded from version D37 to D38 in order to fix a known bug. I can't be certain what the behaviour was before this update.
My S3 is a 2001 model and my girlfriends Golf is a 2000. I doubt, but may be wrong, that her older car has newer software than mine :?
peterb wrote:My little 'experiment' reminded me of one of the other 'clever' features - if you have the two stage unlocking enabled, the automatic unlock on removing the key only unlocks the door which was last unlocked so, after my experiment, my wife's door didn't unlock. The other thing which catches me out almost ever time I go to fill up is that the filler flap doesn't unlock with the driver's door - you need to unlock all the doors.
My filler cap is locked if I open my door with the engine running to fill up, but opens when I remove the keys.
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
peterb
Post by peterb » Wed May 03, 2006 10:50 am
david7m wrote:My filler cap is locked if I open my door with the engine running to fill up, but opens when I remove the keys.
Ah yes, indeed. This only catches me out when the wife is in the car and I, therefore, leave the key in the ignition.
Suzuki Carry 660
david7m
Post by david7m » Wed May 03, 2006 12:36 pm
I've noticed something else on the Golf.
If I open the doors with two presses on the remote, this opens all doors and boot. If I open the boot without opening any of the doors, when I shut the boot, it locks again :? I suppose you could lock the keys in the boot and would need to climb through the 60/40 split :)
My S3 doesn't do this either ...
peterb
Post by peterb » Wed May 03, 2006 6:28 pm
My RS6 re-locks when shutting the tailgate, and the alarm resets - indicated by beep and indicators flashing.
Suzuki Carry 660
david7m
Post by david7m » Thu May 04, 2006 9:05 am
peterb wrote:My RS6 re-locks when shutting the tailgate, and the alarm resets - indicated by beep and indicators flashing.
Do the doors remain open? They do on the golf :!:
david7m
Post by david7m » Thu May 11, 2006 10:01 am
:roll:
CliveH
Post by CliveH » Thu May 11, 2006 10:12 am
Just to add to the confusion, my S4 sometimes locks itself when the keys are in the ignition (and all the doors are closed!)...
Clive
david7m
Post by david7m » Thu May 11, 2006 10:33 am
clive.harper wrote:Just to add to the confusion, my S4 sometimes locks itself when the keys are in the ignition (and all the doors are closed!)...
Now that sounds dangerous!
CliveH
Post by CliveH » Thu May 11, 2006 10:55 am
Fortunately, I was at home at the time, and I had the spare to hand.
You might also have guessed that the doors dont autolock when all the doors are closed, after a timeout period. Anyone know if this is a Vagcom fix or something more complicated?
Clive
david7m
Post by david7m » Sun May 21, 2006 5:15 pm
clive.harper wrote:Fortunately, I was at home at the time, and I had the spare to hand.
Not sure if I follow your last bit, as they should autolock if the doors have been unlocked without the doors being opened. This is just incase you unlock the doors and leave the car, eg if the button is pressed in your pocket when you walk away when shopping etc.
CliveH
Post by CliveH » Sun May 21, 2006 6:58 pm
Dave,
You're correct, that's what they should do, but mine dont that any more, just wondered if there was a fix.
Whats worse is that I once left the keys in the ignition, with all the doors closed, and it did autolock!
Clive
tartan_rob
Post by tartan_rob » Wed May 24, 2006 6:07 pm
Mine autolock but if on entry I only pressed keyfob once therefore only opening the drivers door then when I remove keys from the ignition then only the drivers door unlocks. If I do all doors on entry then all doors unlock. It does not re-lock doors unless ignition is switched off and on.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Return to “DTC / VCDS”
