What is rightmost 'stalk' on instrument cluster?
This stalk was missing on my RS2 when purchased. The dealer (an Audi agency) said it was for use during servicing and there was no stalk there normally. However p40 of my instruction manual shows the stalk, beside the fuel gauge, but with no explanation.
RE: What is rightmost
Hi!
it's used to adjust the tank gauge with a particolar procedure i do have this procedure on my copy of the RS2 eletrical manual but i should looking trough it
Anyway the dealer was right in telling you that it's used just for servicing but the stalk should be shorter not missed
Ciao stefano
Ciao stefano
- shineydave
it should actually be flush with the clear lens of the dash panel. the special tool to adjust it is a piece of tube with an internal spline that slips over the stalk. to be fair i just drove around until my fuel level warning came on then adjusted the gauge to read at the top of the red but there is actually a procedure to set it up correctly
Thanks guys...will take steps to get hold of a replacement.
