B7 LED DRL upgrade bulbs
http://www.EMTuning.co.uk - LED kits that work!!!
Covkiller
Re: B7 LED DRL upgrade bulbs
Post by Covkiller » Wed May 15, 2019 12:59 pm
Error: Left and right headlight
I have just fitted my DRL's to my new headlights.
If the DRLs are set to on before the car is started, I get no error when the car is started.
If the DRL's are set to off before the car is started, I get an error when the car is started. But if I then switch the DRLs on the error disappears.
Any help please Trups :thumb:
RS4 B7, Mugello Blue, K&W V3 & HR ARBs, set up by Centre Gravity, Milltek Valved Non Res & cat bypass pipes, BMC air filter, braided hoses, DOT 5.1, Terraclean, MRC Full Carbon Clean, MRC remap 448PS 477NM, 20" S7 alloys with 4mm spacers & Hawke spigots 66.6 > 57.1, AP Racing front discs.
CocoRi03
Post by CocoRi03 » Fri May 17, 2019 1:59 am
Paddski wrote:
Sun Sep 03, 2017 5:52 pm
Trups wrote:On the way to me transfers Dieppe now. Have a new batch of drls coming in along with plenty of cancellers that will clear this error for good :) will update thread when they are here and send out to you Pete.
I have this error too Trups!
Me too i have this error
Pistolpete2543
Post by Pistolpete2543 » Tue May 21, 2019 10:45 pm
My DRL's are gradually deteriorating. Fine for first 6 months, no errors at all, then getting a very occasional error, now I'm getting error message every time the engine fires up, and now the passenger side bulb is actually dim and flickering constantly.
They look great when working, but reliability is terrible (I've already had a replacement set due to previous issues).
GroundControl
Post by GroundControl » Wed Jun 19, 2019 1:01 pm
I have exactly the same issue with mine. Had some communication with Trups and he sent out some new cancellers, but that didn't fix it. I haven't done anything more to chase up on it since.
Be keen for a fix if one can be found.
Rw@@dy
Post by Rw@@dy » Sat Jun 29, 2019 11:07 am
Decided to remove mine in the end, Trups was helpful but I’m fed up with stripping parts down to swap and test. Think mine had been on 12-18 months, worked well for a period then started to play up. Upon inspection when removed, a number of wires had started to melt through and corrosion on the insides of the cancellers
Pistolpete2543
Post by Pistolpete2543 » Sun Jul 07, 2019 1:32 pm
Yep, same here. A good product but let down by poor longer term reliability. And when I removed mine there was a distinct smell of heat so possibly a liability!
Covkiller
Post by Covkiller » Sun Jul 07, 2019 8:05 pm
Just did mine too. I drive my RS4 every day and the headlight error was getting annoying.
Return to “EM Tuning Lighting”
Users browsing this forum: No registered users and 1 guest
