best way to remove rounded nut
Posted: Thu Dec 30, 2010 2:48 pm
by scooby-tc
as title i have a nut that is virtually rounded,is there an easy way of removing it as space is quite tight
cheers
RE: best way to remove rounded nut
Posted: Thu Dec 30, 2010 4:56 pm
by Blue_Thunder
You can get special socket tools which are made of hardened steel, the inside of them is a 'spiral of teeth'. You hammer the tool onto the nut/bolt, then as you start turning it anti-clockwise it bites in until the bolt finally starts to turn. Don't know the name of them, but Grizz used them on a nut i'd rounded.
Posted: Thu Dec 30, 2010 5:12 pm
by tanoga
Try this
Posted: Fri Dec 31, 2010 11:27 am
by Blue_Thunder
Those are the beasties!
Posted: Fri Dec 31, 2010 11:34 am
by Blue_Thunder
Probably also worth mentioning that even these things do bite into the bolts, it's not so much that the bolt couldn't be used again (unless it's rounded of course!).
